You neglected to indicate what 'fast shutter speed' was. I'm guessing that you were shooting with too slow a shutter speed to stop subject (and your) movement.
Although the 'general rule' regarding action-stopping is shutter speeds of 1/<focal length> or 1/50th using a 50mm lens, I like to stay in the 1/100 and faster regardless of focal length. As I do a lot of indoor photography without a flash primarily with my 24-105, the faster speeds work regardless of where I am zoomed in or out.
The other question I have is...did you actually shoot at an f8 or smaller aperture (higher f-number)? Using the online depth of field calculator, at 50mm and 15ft away from your subject, your DOF at f8 is a tad less than 9 feet...quite sufficient. But wide open at f1.4, less than 18 inches. Depending on how your group is arranged, two rows of people, shot wide open, some faces will be at the edges of 'acceptably sharp'. Even those plus/minus 6-8" from the most-sharp plane will be a little softer, wide open.
Also, you didn't indicate what camera you were using. In my no-flash work, I've found that higher ISO speeds are a requirement to get the fast shutter speeds I need. Depending on which camera body you are using, higher ISO speeds will produce significant noise that will need to be removed. Depending on the algorithms used in your camera to make the JPG, that noise reduction could easily soften the focus a bit. Shooting in RAW, you get to have full control over the noise reduction, and can make choices specific to an image, rather than 'general rules' followed by the camera manufacturer.
