Hi, thanks; all good advice. OK, I guess I'll have to try out a few things at the start before I decide what I can manage (I'm just learning still so this is a tough task).
I'm going to bring my external flash and use it off the camers but if I can't get good exposure I'll opt for the ezybox diffuser on camera. What do you think?
Also, what can I edit in post production? I'm wondering what I can realistically aim for in terms of lighting. Maybe I can fix some things after as long as the photos are moderately exposed and focused?
Yes, I'll try candid photos as much as I can (as long as I fix the lighting issue). I tried last night but the background was dark and when I tried bouncing the flash off a pillar the photo was a little bright.
Also, I have a white polystyrene board and I'll see if that helps bouncing light. I considered making my own white umbrella or using a tinfoil board but I have to choose because the party is in a few hours!
Lo camsQUOTE="astroNikon, post: 3597269, member: 154561"]You may find a shutter of 1/80 may give you motion blur from any movement of you, camera, subject.
To light up the background you need light - another light to light up the background.
but if you want the background in focus, you'll need a smaller aperture to increase your Depth of Field.. Which will require slower shutter speeds or higher ISO to compensate.
what you are finding out with your f/2.8 is depth of field ==>
Understanding Depth of Field in Photography
personally, I wouldn't worry about the background as long as you get the main subject lite up properly and in focus with good clarity.[/QUOTE]
OK, thanks
