jerry12
OK This is my second post.I just got my darkroom set up the way i want and did a test/try out session.
I found an old film canister from many moons ago!
There's was only 6 frames on it and it look like it was from the mid-90's.
But i have some problems that i hope that some of you maybe able to help.
I used Dektol for the developer.I also got a small pack of 5x7 Adorama paper.I don't know why but i got matt finish.I used glossy in the past but Kodak product.
My first question is,how can you tell witch side of the paper is the print side? With glossy finish you can see and feel it but with the matte i could not tell.The first print was upside down and i could not figure out why nothing was happening.
So then i got another sheet and put it the right way,but the sheet is somewhat curl up on all corners.
I can't recall having to deal with this in the past.
How do you deal with this problem? I tought maybe i could get a piece of glass and lay it on top of the sheet. Would that work?
My last question is also about curling but this get pretty bad after the last bath and then hanging to dry.The print curls really bad.
What can i do about it? Is it the paper that i'm using? Should i go with a better product?
What brand of paper do you all like to use? What finish? glossy/matte? RC or FB?
Any help would be nice.It's been a long time since i did darkroom work and my memory is getting worse
Thank you.
Thank you.
Well, I may agree with that. And then I can not compete with 64 years, I am behind of about half of that and rather no chance to catch up. Also thank's for revealing it, when in doubts I know where to knock. I think I will start new tread as here is no place for that, and ask you how do you dry mount RC paper in detail. But that on the weekend.
