Term I've never seen, help please
benlonghair
Woodstock, CT
I'm looking at entering a state photo contest at my local agricultural fair. It refers to "salon prints" and I've never heard that term.
Here's the context: "Each exhibitor may enter a maximum of two photos in each lot. Lot 1: Black and White Salon Print . . . Lot 3: Black and White snapshots. . ."
Any idea what this means? Quick google turned up nothing.
Nails, Hair dressing, Beauty i presume?
Salon prints? Lol, I can safely say I have no idea what that could be referring to.
There is no standard or proper definition. The phrase is most often used to refer to a print mounted on a larger piece of mounting board (e.g. an 8x10 print on a 16x20 board) and possibly with a window matt attached. Contests usually specify a maximum, and sometimes minimum, size for the mount and the print separately.
A salon print is synonymous with an "exhibition print". It means a print designed for display in a gallery situation--and that usually means a larger-than-normal print but not necessarily) and a print that will be viewed under relatively strong, direct illumination, usually from strong,artificial light sources.
A print that is to be displayed under glass, and that will be illuminated with strong artificial light needs to be printed a bit differently that a print that will be hung in, say, a dim, indoor hallway, or which will be presented in a folio or portfolio that will be viewed by normal, everyday office or room lighting.
A black and white salon print, for example, can have shadow values that are quite deep, but which when viewed under bright lighting, will show detail simply due to having a LOT of footcandles' wotht of light shone onto the print.A salon print can have deeper, darker blacks than a normal print designed for regular viewing,or one designed to be shot with a process camera and converted into a halftone for publication.
years ago it also meant to hang all photos in the same direction; ie. the over all mount might be 16x20 all hanging in a vertical direction with the photos under windows going in either horizontal or vertical direction.
it creates a visual balance for a show, rather than having a variety of images in various directions and sizes.
Ah, so it's a form of mounting. Thanks. I couldn't find it anywhere.
Best bet is to contact the category's convener. I've found that especially in smaller fairs meanings like this tend to be mangled a bit. Generally 'Salon Print' seems to refer to a 8x10 or larger fine-art print mounted and/or matted.
