I am totally clueless on what proper WB is and should look like.
I adjusted a bit this photo on the computer and that also might be why this picture is not so well balanced with its light.
But I am glad that the focus is good and the photo is sharp, I have manually focused this one.
Yeah this one is nice and sharp. Regarding white balance, basically your photo is a bit on the yellow side, in other words things that should look white are actually yellow and in your case it's likely due to the colour of the artificial lighting. You can set your white balance in your d7000 under the shooting menu to suit the lighting conditions youre shooting in. If you shoot RAW, you can adjust the white balance later on in either photoshop or Lightroom or whatever other RAW editing software you're using. And as a last resort if you're shooting just JPEG, you can use software to try to make whites look whiter. I used PSE to edit your JPEG to give you an example. Basically I reduced saturation for yellows only, especially on the back wall. It didn't give the best result given I was only working in JPEG but the whites do seem whiter. Check it out below:
Oh thank you I see the difference, what a big difference that is.
Thank you for the explanation, I really need to start shooting in RAW but I am a bit afraid, I am a conservative person and tend to stick to what I know but I know RAW is the way to go so what I might do for now is shot RAW+JPEG and then slowly move to RAW only.
I think my D7K lets me put JPEG on one card and RAW on another so I will do that.
BTW do you agree Nikon did a nice job aligning my camera ?
I believe you saw my pics before and how fustrated I was, now I am happy again with my camera
