The Coffee House
BIM is very very interesting stuff. Sorta like a CAT scan of a building. You can slice it and see what's going on in that slice from different perspectives. Presented your clients a BIM generated model would boost your marketing and give you a leg up over the competition.
Yeah, it can certainly help in getting ideas across. I've just started working with Sketchup which is what one of my colleagues is using for HIS illustrations (he's into home renovation advice, with books, videos, TV shows, radio shows and now, webcasts) and obviously demonstrating the basic ideas is easier with a 3-D image than with a photograph (too much irrelevant detail in the latter). The challenge I'm having is to transition from a basic contractor approach to a more building engineering science approach, without having an engineering degree.
More of a mindset than a degree. When Gary was estimating he saw things and thought them out in 2D. When he put together scheduling and CPM's it was in 3D. When he managed jobs it was all about praying for the inspectors to be blind and not see anything.
More of a mindset than a degree. When Gary was estimating he saw things and thought them out in 2D. When he put together scheduling and CPM's it was in 3D. When he managed jobs it was all about praying for the inspectors to be blind.
My way of working is to have the client be a member of the team. It is, after all, their property that we're working on, and I try to involve them in all the decision-making, especially when we find unexpected stuff and have to figure out what to do. It's also one of the reasons why we spend a lot of time documenting the work in progress - so that we can explain how we did something and why. I have a rather large library of installation photos that I use to explain the details, but I'm attracted to the 3D visualization tools as they can be an excellent way to make clear the key concepts.
Although formally we're a roofing company, in practice I find that we have to deal with the full house as a system, and do the analysis from that perspective. In a climate like ours, when we can go from very cold temperatures (-20C from time to time, and very occasionally, down to -30C), and conversely up to 35-40C (with instances of 100% humidity) in summer, with wild swings of wind, precipitation and temperature changes, it requires a good understanding of how the various systems interact and how certain weaknesses develop into major problems. For example, the lack of air sealing in older buildings is usually not a major issue (other than the cost of heating/cooling, and general draftiness), until someone starts to "improve" by installing new doors and windows, and perhaps add insulation. If this was done without understanding how these changes will affect the overall behaviour, the result is often unexpected condensation and mold issues, ice damming where this was not a factor previously, and deterioration of internal air quality. This is where I think the 3-D visualization tools can be useful, in relating the various elements of the building to its eventual performance.
Buenas Dias Coffee Hosers. Gary just came back from inspecting the front hummingbird feeder ... and it's nearly empty. Those hummers are pigs. Gary is starting his day with a dark roasted Chiapas roasted. Last time Gary ran some guns to the Zapatistas they tipped him with a bag of coffee. Richly flavorful, good coffee is the best way to start a morning.
Au contraire Pierre. The best way to start a morning is to live through the night. 89,000 people die every single night in there sleep for no reason at all. So be happy each morning when you wake up. You were the lucky one that made it. Then enjoy the coffee.
Oh Gary doesn't know about that. For those that only get a few hours of continuous sleep a night ... not waking is like a dream. "... what dreams may come ..."
For your line of work BIM would be useful.
Had to look up "BIM". Yep, I'm kinda dipping my toe in the water, and it's the puddle next to this very large ocean. What I am realizing as I practice "reading " buildings with thermography, is that it reveals a lot of (formerly hidden) detail that needs to be joined with physical construction knowledge. I used to make mockups of certain building assemblies to get my clients to understand what is going on in their house, partly because extensive demolition or deassembly will be required in order to fix the issues, and the mockups allow us to see and discuss the options available to fix the problem. With 3D modelling software, I should be able to have a library of typical issues, and typical solutions in a form that can be rotated, and examined and virtually assembled and disassembled on a viewing device. In reading up on "BIM", I've just came across "FreeCAD", which looks very intriguing. Dang. I'm going to need another lifetime to explore all this.
I got to play with a software package that creates 3D meshes (and orthomosaics) from drone stills - neat stuff. I messed around with some low-end CAD packages a number of years ago. I've also done the old school method of pencils and triangles, though nothing professional; I had to design and create a printed circuit board from the schematic, and build the project for an electronics drafting class back in the late 70s. It was a real challenge - 25 components including at least two transistors or one IC chip and no jumper wires. The teacher didn't care for my zero-ohm resistor.
Gary has never worked residential, mainly government, where the government has its own team of specialists/experts/engineers overseeing the project every single construction day. It is a teaming relationship where trust goes a long way to minimizing paperwork, (for US government the paperwork is equally important as performing the work), and in getting paid (getting paid is important to the contractor on a government job). Gary has worked in extreme temps. Can you imagine a place so hot that the first thing you build is an ice plant? The ice was added to the concrete mix so it wouldn't harden during transport from the plant to the job site.
Well, son of a beehive...the entire greater North Willamette Valley is covered in freezing rain! Early this morning Interstate 5 was closed when a semi truck skidded out of control, and multiple cars domino'd into that, closing the state's biggest freeway for about two hours, from around 4:00 to 6:00 AM.
On I-84, our east-west highway that runs along/through the Columbia River Gorge National Scenic Area, a semi truck skidded off the road and 50 feet down an embankment; the driver got out, but his passenger was stuck in the sleeper cab, and authorities had to knock the windshield out to get the passenger free, and then both were pulled up the embankment by rope. The Columbia River Gorge is an area that often gets hit badly by ice storms; last month the I-84 freeway was closed for a couple of days due to freezing rain conditions.
Ughh...can not wait for warmer weather! There is ice everywhere here. Slippery as all get-out!~
Well, son of a beehive...the entire greater North Willamette Valley is covered in freezing rain! Early this morning Interstate 5 was closed when a semi truck skidded out of control, and mukltiple cars domino'd into that, closing the state's biggest freeway for about two hours, from around 4:00 to 6:00 AM. On I-84, our east-west highway that runs along the Columbia River Gorge National Scenic Area, a semi truck skidded off the road and 50 feet down an embankment; the driver got out, but his passenger was stuck in the sleeper cab, and authorities had to knock the windshield out to get the passenger free, and then both were pulled up the embankment by rope. The Columbia River Gorge is an area that often gets hit badly by ice storms; last month the I-84 freeway was closed for a couple of days due to freezing rain conditions.
Long range forecasts don't necessarily look good for you, unfortunately. Here in the East, the meteorologists seems ready to stick a fork in true winter for us Southern New England folks. I think I'll be back to playing golf by March.
Those diagrammatic electrical drawings require a real skill set to interpret and construct.
It's raining here as well. It was originally forecast for yesterday ... but it finally hit about an hour ago. More of a sprinkle than a real rain ... not enough wetness to keep the Cook from her walk. (She won't walk in a 'real' rain.) There were two pigs comfortably feeding from the feeder at the same time. They must be family.
It's mainly design - where to place the symbols so they are in a (relatively) logical order and the flow is easy to follow. The circuit boards are a bit more challenging (and spatial) in that you have to figure out how to get around all the pieces. One of the reasons wire wrapping was so prevalent in larger computers. Of course, once PCs were being built, multi-layered boards were available. Of course, even a two-sided board (in mechanical drafting) requires things like light tables.
Freezing rain is both very dangerous, and destructive. When we got the freezing rain in 1998 (January 1998 North American ice storm - Wikipedia) we were out of power for about 5 days. First two days were kinda fun. After that it became a real grind. Some people in the country were out of power for a month. A number of suicides of cattle farmers that could no longer cope. Atlantic Canada is getting hit right now (New Brunswick ice storm knocks out power for thousands of residents).
Hopefully the system you're experiencing won't last long.
It is a two-edged sword. After six years of drought in California, water in most any form is welcomed. Most likely, less welcomed, if you personally are affected by the aftermath ... but still welcomed. Gary can't speak for Oregon.
Hey now.. whoa. Back up a bit. How do you know that's the best way of starting your morning? Have you ever tried dying in the middle of the night?
Like mom always used to say, how do you know you don't like it if you haven't tried it?
How you ask. Simple my simian friend. Everything in life and death for that matter has a beginning, a first step. One can not take the first step if one does not reach the starting line. One can not start the morning if one does not reach the morning. To reach the morning is the one and only way to start the morning. Whether it is a happy one is up to you.
No I never tried dying in the middle of the night, I died at 16;42 hours and was brought back to life at 16:44 hours when I was 17 years old . It is not something I suggest that one tries to often. I have done nicely without trying it again all these years.
As for your mom, well I would beckon to suggest that she also told you about Santa Clause, the Tooth Fairy and the Easter Bunny. Didn't know the old girl was such a pathological liar now did you? :allteeth:
Yikes! Be careful out there. Hunker down and wait it out. And Thank You for changing the subject from the incomprehensible (to me) engineering (?) talk that has gone on for several posts. It's Friday. Time for some lighter conversation I think. Hmmmm..........what should we discuss? We could talk about the Super Bowl, or the Patriots, or Tom Brady...
