Thinking of taking an art class. Goal would be to eventually learn to paint landscapes and florals. I have no formal art training. I can draw a tiny bit but it’s been years... Should I start with a beginner level drawing class or a beginner level watercolor class?
@jcdeboever and
@snowbear and anyone else on the site who also paints and or draws.
I'd say drawing first. You'll get all the tips you'll need for watercolors, or any other painting. Being a photographer will be helpful with things like perspective in drawing, too.
Once you get those basics down, watercolor will be fun! I've been playing with oil pastels, and stopped to take a drawing class because it was obvious that I had put the cart before the horse.
IMO, watercolor is the hardest to master. Super easy to over work it. Winsor Newton makes wonderful watercolor, Arches cold press water color blocks are glorious. Water color blocks make things easy, paper gets wet, when dries it stretch's back flat. Draw with puddles of water, drop color in puddle and let it do it's thing. They make hot press paper too (smooth, no texture) which gives a totally different look. I can't say enough about Windsor Newton watercolor, fine pigment. Rubber cement is handy, put it on where you want whites to remain. You can do washes for sky and things but get that paper good and wet first. Porcelain trays work best for watercolor, trust me on this. Micheals has some really good brushes at reasonable prices. The paper and paint is a little high but they usually have it in stock. Cheaps Joe's online usually has the best pricing if cost is goal. Crayola pan watercolors are pretty good, strangely enough. Windsor Newton is the way to go though once your into it. Don't buy the cheap watercolor blocks, they will ruin a good watercolor painting every time.
