- Joined
- Jun 9, 2013
- Messages
- 20,814
- Reaction score
- 13,167
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #14,506
Here they are drying:
Things I learned: the water has to be hot to get the emulsion off, but it doesn't have to be that hot. Also, once it's off, it no longer needs to be hot in order to lift it onto the new surface and manipulate it. This makes it easier to hold my hands under the water to control the movement of the surface and emulsion.
Also, I think I will need to remove a bit more of the milky film that is on the back of the emulsion. Otherwise, the colors wash out a bit, and it's harder to tell which side is "up."
Finally, I believe I have forever reassigned some of my old makeup brushes to emulsion lift duty. Which is fine. I wasn't using them for makeup anymore, and they seem to be well-suited.
Tis a beautiful Friday morn here in the flatlands. Sun is shining, not a cloud in the sky and just a wisp of a breeze. In the 70's today. HVAC guy is here for the annual springtime check of the furnace and heat pump before we need the air conditioning. After that it's off to meet some friends for a late breakfast, hair cut, then add a probe port to the new smoker. After lunch two slabs of St. Louis ribs go on the smoker. #1 son and wife coming up later from Bartlesville for the weekend so the ribs won't last long.
