The posing bumble bee.
Im not the expert here but i can see its a lil bit too noisy... did you try to reduce noise a lil bit?
I like the concept of the picture very much. However, it's slightly OOF, and as others have said a bit noisy.
I don't know a lot about your camera (Nikon) but I did look at your settings during the shot.
Nikon D5100
0.001 sec (1/800)
f/9.0
200 mm
1000
Camera
Exposure
Aperture
Focal Length
ISO Speed
I would suggest a couple of things to try for future shots. I'm assuming these were taken outside (not a greenhouse) so daylight should be enough to lower your ISO from 1000 to around 200-400 range.
You are at your longest focal length for the lens (200mm) so try to back off to the 160-180mm range. Usually you don't get the sharpest focus at full zoom.
Change your f/stop from f/9.0 to f/5.6 which should allow you to bump up the speed to 1/1500 or more will 'freeze' up the wing motion. Although when I was at 1/2000 it still didn't stop it! (smaller bee though).
Lastly, the last bunch of shots I took were in manual focus. I've never tried that before, but it worked very, very well. Just find a spot near where the bees are feeding. Focus in on it, and try to anticipate when they are going to fly (very hard!). Snap away.
Good luck. I'd post a picture, but it's your thread so I'll abstain unless you wish to see some shots I've taken.
Greybeard, as others have alluded to, there are noise, and focus issues. I'm sure you cropped the heck out of these pictures. But just the fact that you could even photograph a flying Bee, just amazes me. I have a hard enough time with them once they've landed on a flower.
This particular bee was very co-operative. He would hover for relatively long periods of time. I wanted to freeze the wings so I shot at iso 1000 and had to crop quite a bit which explains the noise. If I reduce the noise then I start to loose detail so I compromised with what you see. As for focus, it is manual focus at a split second. Even though he is hovering at 200mm f/9 and manual focus it is truly like a shot in the dark. The three shots were the best I got. Thanks for the complements.
Astounding Idea but not so good with the execution. I know this is a very difficult shot well done overall.
