@ the races again
ShaneF
Ontario
A couple photos i would like to share from yet another weekend at the races. As usual any and all comments and suggestion are welcome.
The shots are nice, but WAAAAAAAY to much vignette. My rule for vignette is if you can tell it's there, then it's too much.
#2 has a slant that should be corrected.
Hmm. My email says that the OP replied, but I see no reply ...
This new format has me confused.
I like the empty b/g in #2, and #3 us really good. If it's tack-sharp, I'd love to see a tighter crop of that one.
@ Bender- Thanks for the reply. I have #1 with out the vignette but i in the end liked the heavy version more. #2 could use a straighten. Thanks.
@Lambetpix - I wanted to crop it tighter but for some reason lately i am getting alt of noise in my images and i cant figure out why. Its was middle of the day and i was @ iso 100. I'm not sure why i am getting more noise then i usually do in my images unless its coming from using the CPL.
Tighter crop
Nice! Do you know if the noise is showing up during processing?
sooc i am noticing it more but of course the more i process the photo the more apparent it will become. Do you have any ideas?
Just wondering because I've noticed that processing will often amplify whatever noise is present, especially if I need to boost dark areas. Sometimes, it helps to just paint adjustments like that into specific areas rather than apply them to the whole image, but it's hard to say in this case based just on the "after" image. FWIW, I'm not really seeing a lot of noise at this size, so you'd be in a better position to judge.
