smoke665
- Joined
- Mar 29, 2016
- Messages
- 17,050
- Reaction score
- 10,444
- Can others edit my Photos
- Photos NOT OK to edit
does single spot mean the same as single point af?
Sorry, didn't mean to confuse you, my camera may have settings that yours doesn't, but they are similar across brands. In my case I have a "spot" setting which places the focus area to a limited area in the center of the frame. I use this when hand holding to focus on the eyes. I also have a "select spot" which allows me to move the spot around the frame. I use this when on a tripod, again focusing on the eye. In "multiple points" the sensor is divided into selectable multiple point areas, used primarily on landscapes. "Tracking" tracks the subject when you half push the shutter, think moving car, and "face detection" automatically detects faces and tries to keep the majority of that face in focus.
I use the viewfinder when hand holding set to AF.S. Without confusing you more, the viewfinder uses a different means to reach focus (TTL phase matching) on my model, which gives a quicker, more accurate focus, especially in low light, than the contrast method used on liveview/screen. I'm not sure that having it set to AF.C would hurt. Again, though my personal preference is to use the eyes as the focus point, and any method that uses an area method generally ends up with fuzzy, missed focus around the eyes.
Metering options generally include "spot", "center-weighted", and "multi-segmented". Again, when I'm in manual mode I use "spot" choosing to "spot" meter areas myself and make adjustments as needed.
