- Joined
- Oct 11, 2021
- Messages
- 13
- Reaction score
- 39
- Can others edit my Photos
- Photos NOT OK to edit
Any / all feedback welcome. I don’t know much about photography but am trying to learn.
I don’t know much about photography…
Not only upward, but any off-center axis composition. You get the opposite phenomenon when focusing downward. Depending of the focal length of the lens, the distortion can become more enhanced, especially the shorter the focal length. An extreme example is the fish-eye lens. Distortion is a bit minimized with lenses as wide as 24mm. Wider than that, and the distortion becomes more pronounced.Thanks for the responses. I’m guessing vertical angling means having the lens pointed upwards?
This is helpful, thank you. I’m not sure if I have front/rear axis adjustment, but I do see my lens has a fw update and has some calibration software that I’ve yet to utilize (Sigma 14mm f1.8). Perhaps that will help. Thanks for the feedback and suggestionsNot only upward, but any off-center axis composition. You get the opposite phenomenon when focusing downward. Depending of the focal length of the lens, the distortion can become more enhanced, especially the shorter the focal length. An extreme example is the fish-eye lens. Distortion is a bit minimized with lenses as wide as 24mm. Wider than that, and the distortion becomes more pronounced.
With wide angle lenses, you also have to take care when using polarizer filters. Those are designed to be used within a fairly narrow limit, in order to be beneficial. As you get further off-axis, the polarizing effect also becomes distorted.
Users of view cameras have rear and front axis adjustments to compensate for this type of distortion (within limits). You can also correct this type of distortion, to a degree, in post-image processing.
