Triggering External Flash with Canon T4i
Fuganater
Pittsburgh
Does anyone know how many external flashes I can trigger with the Canon T4i? I know I can do 1 but not sure if it can do 2 or 3.
If you're looking for custom flash ratios you can have up to 3. You have groups A, B, and C. Each flash can be assigned to different group and each flash in each group will fire at the same power level. So in short you can have actually more than three, but if you want them to all fire at different ratios each one needs to put into a separate group limiting you to 3 total. Hope that helps.
Info starts on pg. 226 in the manual.
http://gdlp01.c-wss.com/gds/5/0300007695/01/eosrt4i-eos650d-im-c-en.pdf
Cool thanks. I'll look into that. I didn't think to look in the manual because I don't have it on me.
