nycphotography
- Joined
- Dec 7, 2012
- Messages
- 963
- Reaction score
- 262
- Can others edit my Photos
- Photos NOT OK to edit
Basically, an exposure is a "bucket filled with light".
It helps to visualize a graduated cylinder filled with water. Imagine targeting the 250cc line on a 500cc graduated cylinder as the correct amount of light / water for an exposure.
When taking the exposure, it's like filling the graduated cylinder with a hose.
There are FOUR variables in the process of filling a glass of water.
1) the size of the glass
2) the size of the hose
3) the pressure of the water
4) how long the hose is on
Same thing for an exposure
1) the iso of the film (equiv to the size of the glass)
2) the aperture (size of the hose)
3) brightness (the pressure of the water)
4) shutter speed (how long the hose is on)
In pseudo math, a proper exposure is BALANCED and is: ISO = (some function of) Aperture, Brightness and Time.
Now, if you are UNDER exposed (ie, only getting 125cc of water instead of 250 in a 250c glass)
You can do four things.
1) You can INCREASE the pressure (brighter light = more pressure)
2) You can increase the size of the hose (lower aperture = bigger hose)
3) you can get a smaller glass (higher ISO = smaller glass)
4) leave the water on less time (faster shutter = less time)
In photography, "stops" for everything is DOUBLE and HALF except for aperture (which is an area so it's squares and halves, but luckily, you can simply memorize the fstop series as 1.4, 2, 2.8, 4, 5.6, 8, 11, 16, 22, 32)
The advantage of fstops is that they can simply be added and substracted. So ISO = APERTURE + BRIGHTNESS + SPEED. If for ANY exposure where the equation is in balance (ie you are getting 250cc in a 205cc cup) you can make "OFFSETTING" "FULL STOP" adjustments and stay in balance.
For example, you can make any of the following adjustments and stay in balance:
one stop faster on shutter (1/125 -> 1/250) and one stop faster on ISO (400 -> 800) (off setting because opposite sides of equality / balance point)
one stop smaller in aperture (f4 -> f5.6) and one stop slower in shutter (1/250 -> 1/125)
one stop dimmer in light / flash (1/4 power -> 1/8 power) and one stop wider in aperture (f5.6 -> f4)
you can also make multiple adjustments at once as long as they all add up / balance across the = sign. One two stops slower on ISO, 1 stop slower on shutter, one stop wider in aperture.
And if I'm off (say -2EV/stops) on the light meter, I can fix that, AND make other changes all at the same time with one set of adjustments. Lessee... I need to BUY two stops MORE light (water). Let's get half by making the glass one size smaller (ISO 100 -> 200) and let's get the other half by making the aperture one size bigger (f4 -> f2.8). Now I've made two unbalanced adjustments that cumulatively get me the 2 stops of light I need.
The advantage of fStops is that they're "normalized units" so you can simply add and subtract them. I find that thinking of it as stacks of "fstops" on balance scale (which is much simpler than water and cups, thus the advantage of normalized units) can also help. Is the left side two "fstops" off from the right? Start adding stops on one side or taking them away from the other until you get it in balance.
Hope this helps.
Hope this helps.
