Two Versions
Frequency
Calicut, Kerala,India
Regards :D
1.B&W :) , thats my pick.
( I never go color unless there's really lots of vibrant colors in the scene ).
2.Just being nit picky, right around the center ( above the clouds ) there's a noticeable flare, easily removed using photoshop patch tool.
3.As for the other flare spots, its going to difficult to remove.
B&W for me too...though I would give your try at cloning the horizon out or cropping it out. There's just not enough of it for interest and all it does is distract from the sun/sky...which is the real focus of the image.
More than reading, both comments are accepted and appreciated
Thank you Vinit
Thank you NateS
Regards :D
I like the effect the sun gives to the image. I would suggest brightening your mid-tones to make the white of your clouds whiter, as I feel they look a bit too under-exposed.
Also the color image appears to have a strong blue cast, a quick colour balance adjustment would fix that easily. I agree with the suggested crop, however I feel the image would be stronger if you had found a spot with trees all the way along the horizon, to anchor the image and make the sky seem larger.
Nice work!
I approve to your comments JC. if i remember right i took this through the window glass of a speeding car....
Regards :D
