Umbrella vs Softbox
Ballistics
20110815 by Compressed Memories, on Flickr
My first question is, am I able to achieve the same effect with a monolight shot through an umbrella? I took this with a makeshift softbox I made out of cardboard.
My second question is, what is the main difference between shooting with a softbox vs an umbrella?
A softbox is more directional with its light pattern than an umbrella.
With your example, I would bring the main light forward (feathered towards the camera). Notice the hotspot on the nose and the deep shadows on the left side of the mask. I would also ask the model to shift her left shoulder away from the camera to create a more dynamic pose. Seldom is "square to the camera" an affectionate pose. You might also consider a rim light to the back of the head to add separation from the background. And while I'm at it, some fill light or a reflector to lessen the shadowed side of her face/hair.
Can I achieve the same effect with an umbrella?
You can get the same lighting pattern with an umbrella, that's the easy part. But there are differences.
For example, an umbrella tends to spill light all over the place, so if you are in a small space with reflective walls, your background may get a lot more light with an umbrella, than it would with a softbox. So it might be harder to pull off a dark field shot like this.
Another way that light modifiers will differ, is how the light falls off and transitions into shadow. This will change even from one softbox to another or one umbrella to another. It will change depending on how close the umbrella is to the light etc.
If you Google 'light modifier comparison' you should come up with several sites that show you examples of what the photos will look like with different modifiers. Sometimes it's a subtle difference, sometimes not.
Here is one I found....MODIFIERS
Also lower your camera angle :sexywink:
Thanks for the link
