Upgrade to D7200 or FX Body?
I am so conflicted over this decision. My old D7000 (after I fine tuned the auto focus to -17) is working just fine. I know this camera like the back of my hand and it does what I need. How much better is the D7200? or to see a real improvement do I need to look at the D750? I can't make up my mind!
I had a D7000.
With the D7200 or D750 you'll find a similar camera in features and layout. A few differences of the left buttons variation, menu options, etc which is quite obvious if you keep the D7000 and add the D7200/D750.
The biggest difference between the D7200 and D750 is DX vs FX. If you find yourself missing photos due to low light then the D750 is the better choice.
When I bought my D600 I kept my D7000. So I used them side by side for a while. The low light, 2 stops faster, ability is quite astounding once you get used to it. DX is good, but FX is that much better. You gain more low light flexibility, and if you have or had FX you understand.
If you use them in a studio environment it really doesn't matter. Daytime sports didn't matter too much, evening sports the FX started shining in waning light. If you do long distance shooting then the DX will help maintain detail (for 24mp DX vs 24mp FX, for 16mp DX and 24mp FX the FX actually was a bit better for me for long distance).
One of the main issue is lenses. With DX many people have variable focal length lenses. If you use the kit lenses you are handicapping the cameras flexibility. If you use a fixed aperture lens then you are allowing the camera more flexibility. Just look at an 18-200 which is f/5.6 @ 200mm versus a 70-200 which is f/2.8 @200mm. 1 stop of light variance right there, a further handicap to a DX sensor. You can also compare that to a AF-D 28-200 FX lens which is also f/5.6 @200mm. Basically losing a stop of light versus a better lens.
So just by lens choice you can easily gain 1 stop of light on DX
or 3 stops improvement moving to FX with a f/2.8 lens; or just 2 stops by using a variable FX lens.
If you make sure you have good lenses to begin with then that lowers the variance. When I bought my D7000 I only had the kit 18-105 lens, all other lenses I bought were FX AF-D. The D7000 body focus motor allowed me to buy AF-D lenses, versus having to buy more expensive AF-S lenses if I bought a D5x00 or D3x00 camera. It was much cheaper getting a better body, and then FX AF-D lenses, than a lower DX with more costly lenses.
So moving to FX vs DX the main issue is how many low light shots have you not been able to make due to low light ability. Then could a better lens of helped? Or does the move to FX become more feasible. It is about 2x the price for d7200/d750.
But moving to the d7000 to the d7200 (no AA filter) you'll gain IQ and croppability. a 24mp image vs 16mp image, and i think 1/2 or 1 stop better ISO control. Max ISO I used on the d7000 was 1600. So the d7200 is better at low light than the d7000, but less so than a FX camera.
FYI, I still miss my d7000 and d600. Sold both of them. I found myself never using the d7000 and the newer features of the d750 made the d600 were enough to sell that.
What blunts this argument is whether or how often one finds it necessary to pull images from the murk of under-exposure. If you're not dredging up such files constantly, a DX like the D7200 just isn't axiomatically inferior to a prosumer Nikon FX--certainly not enough to warrant the price spread between current comparable DX/FX bodies.
A good used d600 can be had for the same price as a d7200.
Sent from my N9518 using Tapatalk
"A good used d600 can be had for the same price as a d7200.
I am most interested in the newer focusing systems on the d7200 and d750.
If you shoot a lot of action shots the better af can be nice. Honestly I haven't had any issues with the d600, the af keeps up just fine for me.
Consider the viewfinder system of any camera you are considering purchase of. Go to a store, and look through the viewfinder. Consider if there is an articulated rear screen, or not. Evaluate the viewfinder image itself: its size, and its clarity and its quality. There is a real difference between what is seen through the lower-level pentamirror cameras (D3xxx and D5xxx-level models), between the DX-format pentaprism cameras, and the FX-format cameras of the consumer-type body level, and the flagship cameras, like the D3,D4,and D5 series.
For some types of photography, the view through the viewfinder when the camera is held at eye level, can be important. If your vision is not really fantastic, the larger, better view through an FX camera can be of some help. Some people are going to be framing and composing on a tripod using Live View and the rear LCD screen, and not making when to shoot or not shoot decisions based on what the viewfinder shows. For these people, the image thru the viewfinder will not be a big deal, really.
On the lower end, the pentamirror models, Nikon has slowly but steadily been increasing the viewfinder magnification over the generations. As far as physical SIZE, the FX cameras have a bigger through the camera image. Look at the eye relief in millimeters specification. But do try to get to an actual store, and compare cameras side-by-side, and see how the viewing system works for you,and your eyesight, user of eyeglasses or not, etc.
The D500 viewfinder is worth a look, it is not worse that most of the Fx finders I have used.
I'll keep that in mind. I'm keep flip flopping between the d7200, d750, and d610. I shoot a lot of close up with my 105 macro and macro flash setup.
Honestly you can't really go wrong with any of the above. Not a bad choice in the bunch.
Well, my wife gave me the OK so I just pulled the trigger on a D750 with 70-120 f4. I'm pumped.
This is a very good choice, especially the lens. One of the best lenses Nikon makes in absolute terms and a bargain for what it is. Have all the fun in the world with that combination! The D750 is also a very good camera, I would have bought one if I not already had the D600.
70-120?
70-200/4 ?
If you have any setup issues with your d750 PM me .. I've had mine for a few months and a D600 & D7000 before that. You'll find it fairly similar in setup just with more features and things.
70-120?
70-200/4 ?
Thanks, I'll keep you in mind.
