Useful Article I stumbled upon T1i vs T2i
Pros of the Canon T1I VS T2I
Pros of the T1I:
- The shutter lag has 40% less delay then the T2I.
- It is slightly cheaper to purchase.
- Has 30% less start up delay.
Pros of the T2I:
- Is quieter at a high ISO (.3 f-stops)
- Longer lasting battery
- Quicker shutter speed
- Better light sensitivity
- Better ergonomics
- More impressive video mode
- Has external mic jack
- Larger image size (5184 X 3456 VS 4752 X 3168)
- Higher quality LCD monitor
- Has additional memory card compatibility (SDXC).
The terminology used in this article is incorrect. It isn't "quieter" at high ISO, it handles noise better. It doesn't have a "higher shutter speed", it shoots in burst mode with a higher FPS rate. "Better light sensitivity" also refers to ISO, and the Camera's ability to handle noise. The shutter makes the same amount of noise regardless of the ISO.
