Helen B
- Joined
- Sep 16, 2007
- Messages
- 3,296
- Reaction score
- 467
- Location
- Hell's Kitchen, New York
- Can others edit my Photos
- Photos NOT OK to edit
Most calculations of DoF come from an original idea that a CoC of 0.2 mm is acceptable for an 8x10 print. The acceptable CoC for the film or sensor format is calculated from that. It isn’t the other way round.
The value of 0.2 mm can be arrived at by considering visual acuity at the ‘comfortable near distance of distinct vision’, which is about 250 mm. At that distance a high contrast line of 0.075 mm width can just be distinguished. In practice this is relaxed a little, to give a practical value of 0.1 mm. A ‘line’ is a cycle between dark and light, so the corresponding acceptable circle of confusion is 0.2 mm (one cycle).
Here are the commonly used values for film formats based on the 0.2 mm criterion:
8x10 (inches): 0.2 mm
4x5 (inches): 0.1 mm
6x7 (cm): 0.05 mm
24x36 (mm): 0.025 mm
These assume that an 8x10 print made from them is viewed at 250 mm, or a 16x20 at 500 mm etc in proportion – ie keeping the angular size of the print the same. When you print large, people have a tendency to approach the print more closely, especially when there is fine detail to be found. This raises the required definition in the print, making DoF calculations based on 0.2 mm inadequate. Because CoC and f-number are both linear in the simplified DoF equation you can make an allowance for a smaller CoC by using a smaller f-number. For example, if you have a lens that has a DoF scale based on a CoC of 0.033 mm you can use it for a CoC of 0.025 mm if you use the f-number markings for the next smaller f-number in full stops. If you were using the lens at f/16, you could use the DoF markings for f/11.
Over the years the CoC used to compute the DoF markings for Zeiss lenses intended for 35 mm still photography has decreased from 0.033 mm to 0.030 mm to 0.025 mm. This has been documented by Zeiss. The decrease is largely due to improved film and lens resolution. The same has happened in the movie world – we are now using smaller CoCs that we did when I started over thirty years ago.
Here’s what David Samuelson (who designed one of the more popular DoF calculators for use with motion picture cameras) has to say:
Cameramen should be selective in choosing the depth of field they work to, using 0.05 mm or more when the circumstances are easy, 0.025 mm as a middle-of-the-road value and 0.0125 mm, or even less, when tolerances need to be tight.
He’s referring to 35 mm motion picture formats.
Best,
Helen
6x7 (cm): 0.05 mm
Best,
Helen
