I would use a longer shutter speed to smooth out the water
Next time try 1/30 second at f/20 or use a neutral density filter to get away from f/20. You need a slow shutter speed when shooting flowing water. 1/30 second is marginally slow enough, 1/15 would be better if your aperture goes high enough.I would use a longer shutter speed to smooth out the water
My settings was 1/500 5.0 ISO 100
Next time try 1/30 second at f/20 or use a neutral density filter to get away from f/20. You need a slow shutter speed when shooting flowing water. 1/30 second is marginally slow enough, 1/15 would be better if your aperture goes high enough.My settings was 1/500 5.0 ISO 100
Thank you!! I will try this tomorrow.
The actual settings will vary depending on the light. The bottom line is to use a tripod and the slowest shutter speed you can get away with. The slower the shutter speed the more water will pass in front of the shutter while it's open giving it a silky look. Kind of like this one (1/6 second at f/25):
I'm having trouble opening your pic
