if it does have some fog you can add some benzotriazole to the developer to aid in reducing the fog. use about a .2% solution add about 15ml at a time to a liter of deverlop.keep adding until the fog disappears.
Benzotriazole is primarily a restrainer, that is it inhibits unexposed silver crystals from being developed. In fogged paper and film the crystals have been exposed so you cannot inhibit their development. Any reduction in fogging by increasing the chemical concentration is caused by it working as a bleach. At this point it will not only remove the fogging but some of the rest of the image as well. It's usefulness is therefore very limited and it's effect are certainly not enough to justify using more of it when you look at it's COSSH profile.
It is a skin sensitiser that can cause dermatological problems, it is mildly toxic and, as it does not biodegrade, it is a pollutant.
In silver photography the process depends upon electron release and ion migration. Photons being absorbed by silver crystals is the main way of promoting this behaviour but it means that there are other ways too.
Shorter wavelengths like x-rays and gamma rays will quite happily work the same and fog film and paper. So too will ß particles from radioactive sources.
There are also a number of chemicals which work as electron donors and so will fog film. These are often used in colour reversal processing to give the second 'exposure'. Some decomposing plastics can give off fumes that will fog film, and I believe formaldehyde vapour does it too. And some compounds containing sulphur can also cause problems.
As long as you store materials in approprite sealed containers and keep chemicals seperately stored this should not realy ever be a problem.
