What's the general consensus on macro extension tubes?
arcooke
Plano, TX
Just curious about what those who have ACTUALLY USED THEM (as in, I'm not interested in hearsay or speculation) have to say about them. Seems these tend to be a controversial subject from what I've seen around.
I've been wanting to get a macro lens to see if that's something I'd like doing.. but thought it might be smarter/cheaper for me to drop a few bucks on extension tubes first instead.
Would they pair nicely with my nifty fifty?
Amazon has a fairly well-reviewed set of Zeikos tubes for $75, which is easy to swallow (there's 3 of them: 13mm, 21mm, and 31mm).
Thoughts?
Thanks :thumbup:
I have a few sets of tubes...in vintage from the 1970's to the 2000's...for $75 the three-tube Zeikos set looks pretty decent. A 50mm 1/8 will work "okay" with extension added...it'd be nice to have a longer lens available too, something in the 85 to 200mm focal length range is often nice.
Thanks. I also have my 18-105mm kit lens, how would that fare?
Any comments on the sharpness/overall quality of shots taken with extension tubes compared to a dedicated macro lens (assuming a decent lens is attached, of course)?
The 18-105 ought to fair okay with tubes, at the longer settings. At short focal lengths, the tubes will cause the MFD to be inside the lens barrel itself,so....
Using a regular lens with tubes will give decent results on most real-world, 3-D subjects, as long as the lens is stopped down a little bit. FLAT, highly-detailed items, like say stamps or currency, will show the optical weaknesses at the edges of the frame, but the center of the image is usually pretty good with a regular zoom, whereas with a dedicated macro lens, the image quality will be very high to excellent, across almost the entire frame. On real-world scenes, the edges of the frame are quite often out of focus background stuff...and so the edges really do not impair the image in any meaningful way.
Very helpful info, thanks Darrel!
Extension tubes seem to be a controversial subject? Guess I musta missed that one (and probably glad I did)...
I started my macro journey with a reversed 50mm lens on a Nikon F about a million years ago using a really cheap adapter. Here's one of my shots with that:
Cigarette Ash
Eventually, I got a set of Kenko extension tubes and my macro capability expanded. Here's a shot using them on a 100-400mm lens:
Tongue Tasting Monarch
Then I got a 180mm Macro lens:
Monarch With Pink Buds
And I often put my extension tubes on it to get in even closer to my subjects:
Eye Of The Dragonfly
I like extension tubes and recommend them to anyone who wants to start shooting macro, especially on a budget. Even after one gets a true dedicated macro lens, the tubes will continue to be something that can be used effectively in the pursuit of macro photography.
Controverial, huh? Pfft... Fiddle-faddle, I say. ;)
I absolutely could not live without my tubes. I use it to go beyond 1:1 but there are so many shots of small critters that I can get shots of with tubes than without. You lose some light which can make the viewfinder a bit dimmer, but outdoors, I never have a problem seeing and focusing...even with the full set (all 3) tubes on. I have Kenko Tubes, but the same rules apply.
On my site, probably 90 percent of the insects and arachnids were shot with at least one tube attached. My most common and "go-to" setup is the full set of tubes with my 180mm macro...you wont' regret the tubes purchase and I only regret not getting a set sooner.
Great shots there. That dragonfly has a striking resemblance to Homer Simpson :lol:
While we're on the subject of Macro (and noticing that the OP also uses Nikon), what are the thoughts on the Nikkor 105 f/2.8D Micro vs the new model with VR? I'm almost set on getting the older D because it is cheaper, and from what I've read, it is actually sharper, handles CA better, and is more consistent in performance from f2.8 down to about f/16 than the newer version. The newer version has the internal focus and VR, but is this really going to make much difference? Can you really take 'good' sharp macros handheld anyway?
BTW Buckster, your post of the dragonfly head has me seriously considering picking up a set of extension tubes now even though I was going to get a macro lens anyway. I've read that the extension tubes will allow greater than 1:1 on a macro lens, but I really didnt expect THAT kind of result. What is the working distance for that kind of magnification?
For background, that was shot at f/22 with all 3 Kenko tubes on a Sigma 180mm Macro using a Canon 40D (crop sensor) and my DIY Macro Flash Bracket holding two 580EXII speedlights.
As I recall, I'd worked into within about 6" of the beast when I got that shot.
Those look really nice darkhunter, thanks.
Now I don't know what to do, haha. I'd imagine extension tubes would be more versatile since you don't have to worry about matching them up with the filter size that the lens uses, or buying step up rings
any chance you can share more info/have pics of that DIY macro flash bracket setup?
thanks
mark
thanks
mark
Here you go: Buck's DIY MFB
