Digibill
- Joined
- Apr 3, 2013
- Messages
- 93
- Reaction score
- 14
- Location
- manchester,NH
- Can others edit my Photos
- Photos OK to edit
I think your right on the over sharpening,they were so noisy sooc that I think I went over board .As for the over saturation thats kind of the point for me in this kind of picture.Not bad. The first two look horribly over sharpened with a bit too much saturation on the colors. Overall a good start, with the third being my favorite.
Jake
Sent from my iPhone using Tapatalk
Thank you it's a fun way to enjoy photography during the winter monthsthe last one is beautiful.
I love photography in the winter. :cThank you it's a fun way to enjoy photography during the winter monthsthe last one is beautiful.![]()
I'm using an yongnuo 560iii.I learned later that if you let the room get to smokey it comes across as noisey.They all were shot at ISO 200,also more ambient light allows you to focus on the smoke better.I also scrimmed or blocked the flash (or whatever you call it)from hitting the black foam core.here's a couple from a different session.I like the last one. It's much simpler and not as busy.
What are you using to light up the smoke?
If you're using a strobe light (flash) you should be able to use a lower ISO setting so image noise is minimized.
Also, nailing the exposure is critical for minimizing image noise.
You can crop to isolate smaller, interesting sections, and you can change the orientation of the frame so the smoke isn't rising out of the bottom of the frame.
