X-pro effect like instagram
jespergb
Hi.
Anyone know where i can get an action to make an x-pro ii effect like seen in instagram?
Also is there any available effects to make the current contemporary effect that desaturate and contrast adding photos?
Or maybe a professional package for those effects?
cheers
Which program do you use for PP work?
If you use GIMP, there is a plugin you can install (Cross Processing | GIMP Plugin Registry). It requires Python (if you have it, it will be under filters-python. If not, download it here: Download Python).
The results of doing your own x-pro will be much better than using an action or something like instagram. When you do the x-pro yourself, you can make adjustments so the photo is exactly where you want it to be.
Follow me on instagram: 123elaela123 :)
