35mm = to 50mm on cropped sensors?
Discussion in 'Photography Beginners' Forum' started by divided, Dec 7, 2007.
  1. divided
    divided TPF Noob!
    Nov 29, 2007
    54
    So if i wanted a true 50 mm FOV on my XTI, i would need a 35mm lens? Is that correct? Along the same logic, does that make my current 50mm 1.8 prime, eqivalant to a 85mm on a 35mm camera? IS this all correct or am i missing something? Is their a chart anywhere with all the conversions for cropped sensored cameras?
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    with respect to the angle of view provided you are approximately right.
    however, even though the angle of view is approximately the same for a 50mm on full frame and a 35mm on a 1.6 crop, depth of field will be different. The smaller sensor gives more DOF than the larger sensor at the same aperture.
  3. divided
    divided TPF Noob!
    Nov 29, 2007
    54
    The smaller sensor gives more dof, does that mean more is in focus while shotting wide open? If not, can you clairfy, thanks.
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    more or less, yes, if the distance to the subject is the same.
    p&s cameras with their extremely small sensor have a very deep DOF, which for example sometimes makes it impossible to get a blurred background
    in a protrait ... even in cases where on a 35mm full fame SLR a slow lens would give a DOF shallow enough.
  5. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    uhm .. technically my typing was certainly not 100% well phrased ... but practically this is how things behave.
  6. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    you basically have it all right, my man.
    But you don't really need a chart. Multiply your regular lens by 1.6 and you get the equivalent when you put it on a crop camera.
  7. DSLR noob
    DSLR noob TPF Noob!
    Feb 7, 2007
    1,527
    7
    Atlanta, GA
    at first glance this seems bad because you lose wide angle photography, but your telephoto lenses have a greater effect, and if you want wide angle photography EF-S lenses(can only use on crop sensor bodies) go down to 10mm, or a pricey sigma fisheye goes to an astounding 8mm
  8. the_beginner
    the_beginner TPF Noob!
    Jan 31, 2005
    41
    Northern Illinois
    Alex_B - thank you for confirming that I'm not crazy. :)
    I recently upgraded to a DSLR from a P&S and noticed way more bokeh (I think that's what it's called) in my pictures at wider apertures. It's much easier to get something to pop off a background.
50mm in crop sensor actually
50mm on crop sensor
