Anyone ever get two filters stuck together?
Jon_Are
Yeah, I did. My ND seems to be welded to my polarizer. I've used my last ounce of finger strength in attempts at separation, but no go.
Short of putting it in a vise - which I know is a recipe for disaster - I'm at a loss.
Anyone else have this happen?
Thanks,
Jon
I have found that if you use your fingers and put them EVENLY around it, then you have a better chance than just using two fingers or gripping it with your hand and trying to turn.
Hope that helps ya
~Michael~
Do you think if it is possible to put a rubber band on each filter and try?
On my lens I keep a UV filter on it all the time. Once in a while I put my CPL ontop of it. I have found theres a "sweet spot" when turning the CPL that sort of "unlocks" it from the UV filter. It may be my imagination or something, but I have tried to unscrew them as best as I could and then I would turn the CPL a little bit at a time and theres one point where it takes very little effort to unscrew them. I was surprised and thought I was the only one that experienced this. I'd say give it a shot.
Light a match under them. Kidding, but try applying a touch of heat to loosen things up. Had it happen to me once, just warmed them up with the heat from my hands. Good luck.
If you're a smoker, you're in luck!
I just find that we tend to have a better sense of what a lighter will and will not burn from certain distances. If you're going to do it with the filters, which actually IS NOT a terrible idea if you do have the "touch", for the love of god don't put flame directly on them.
Could try sticking them in the freezer for a bit. One filters ring may contract faster than the others. Also try tapping them lightly on a countertop corner like you do a jar that wont open.
That's what always works for me.
I appreciate all the replies, I'll try them all.
In the meantime, it occurred to me that a couple of rubber tourniquets might do the trick.
I won't get my hands on them, though, until work tomorrow. :mrgreen:
I'll let y'all know.
Jon
I like the temperature idea. I would set the top one flat on a frozen steak or something for about 10 seconds. I bet it just slides after that.
The trick is, as mentioned, try to use even pressure around the circumference. Squeezing only a couple points will put pressure on other spots, making it even harder.
To prevent this in the future, try using a regular pencil to get some 'graphite' onto the threads. This will act as a lubricant and make it easier to unscrew.
Great idea, Big Mike. I will do that.
Jon
Wow big mike.. that is a great idea .. Let me do that as well. Just in case.
