tecboy
- Joined
- Feb 17, 2012
- Messages
- 2,977
- Reaction score
- 358
- Can others edit my Photos
- Photos OK to edit
Not really because I have no idea of your set-up, conditions, etc. Why not do a comparison against the YN or Canon model?You can tell from the photograph. Heavy vignette at wide angle shot. That is not normal compared to Yongnuo and Canon speedlites. It could be defective.
Hmm. Ok, if I have time tonight, I want to try the same thing, under the same circumstances. Shortest I have is 18 mm, so I'll have a go with that.I've talked to him and he said,
"Seems that the length of 15mm is too short. the performance of the flash cannot cover that distance.
it is suggested that you use a minimum focal length of 24mm.
Thanks
Best Regards"
Thanks
Best Regards"
Mmm.. No.Hmm. Ok, if I have time tonight, I want to try the same thing, under the same circumstances. Shortest I have is 18 mm, so I'll have a go with that.I've talked to him and he said,
Thanks
Best Regards"
Hey, do you want to trade Aperlites?
Just kidding, bro.Mmm.. No.Hmm. Ok, if I have time tonight, I want to try the same thing, under the same circumstances. Shortest I have is 18 mm, so I'll have a go with that.I've talked to him and he said,
Thanks
Best Regards"
But, why don't you try using the wide angle diffuser to see if that helps?
