Are UV and polarized lens filter a necessity?
Discussion in 'Digital Discussion & Q&A' started by DScience, Apr 17, 2009.
  1. DScience
    DScience No longer a newbie, moving up!
    Apr 12, 2009
    1,513
    122
    Denver, CO
    The title says it all...When I purchased my DSLR last week, the sales guy tried to convince me that a UV lens filter is something that all photographers use to protect their lenses, and he said the polarized ones are great for almost all occasions?
    So I'm wondering if most people here have either filters, and if you do when do you use them?
    Also, are they important and are they something you keep on ALL the time??
    Thanks everyone!
  2. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,215
    239
    Los Angeles
    I have UV filters on my lenses with larger front glass (67mm 77mm threads) to protect it from stuff flying at it. I shoot car events and sometimes there's bits of rubber and dirt flying around. I'd rather it hit a filter than the actual lens glass. I don't use uv filters on my smaller lenses (52mm filter size). I leave the UV filters on all the time, unless i'm putting my polarizers on, which are used to reduce reflections on shiny things (cars usually for me), or to add more contrast in the sky, in which case I take the UV filter off so i'll be shooting through less glass.
  3. DScience
    Apr 12, 2009
    1,513
    122
    Denver, CO
    Thanks for the reply!
    So if I understand correctly, having the UV filter on will never have a negative effect on the picture quality? it's simply for lens protection?
  4. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    UV and Polarizers serve different functions. If you want a front filter for protection, I would suggest looking at a clear glass filter. I don't use them usually, but have a couple if in situations as bhop mentioned or at the beach on a windy day.... or similar where dust, debris, moisture, etc causes you to have to wipe the lens often.
    There have been several threads on this discussion. Try using the Search tool.
  5. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Depends on the quality of the filter. Look at it this way. You are placing another item in front of your lens. Make sure it is a quality filter. I have spent close to $200 on a filter, but it is riding on a $1700 lens. The cost/benefit is up to you.
    A poor quality filter will have a direct impact on your image quality.
  6. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    For the record, in your original post, it sounded like you were calling a Polarizer a type of UV filter. It is not -- a polarizer has a specific function, which is to admit light which is polarized in only one direction. This has the effect of darkening skies and removing reflections from glass and water. It also absorbs around 1-2 stops of light (depending on quality), so it is not a good idea to have one in low light situations. But, polarizers are awesome when you need them -- it's one of my absolutely standard filters which I carry almost everywhere.
  7. DScience
    Apr 12, 2009
    1,513
    122
    Denver, CO
    Yea I have no worries about foreign objects hitting the front...i'm more worried about the UV rays. But, I don't see the point in getting them if they will make the quality of picks worse, with the added piece of glass.
  8. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Fogot to mention....... I always use a lens hood as the first line of defense for protection. The second line is common sense along with just being careful.
  9. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    UV protection really isn't necessary nowadays. At one point, UV light could cause trouble on film -- but it's not an issue on digital sensors, nor even most modern films. UV filters really are just protection from foreign objects nowadays.
  10. FrankLamont
    FrankLamont TPF Noob!
    Feb 20, 2009
    556
    Basically, a UV filter can do both things; protect your lens and reduce UV. Really useful when you're hiking up high, with more UV radiation... still, the problem is ghosting and flaring - two common issues that come up with cheap and basic UV filters. I suggest that you get yourself a multi-coated UV filter, with at least 95% transmission... Hoya series is good, but make sure it's the multi-coated version. The pro multi-coated version is only around $60, and hey, don't put a bad glass in front of an awesome lens.
    Polarising filters are different. Yes, they can protect your lens as such, but note that it really hightens the saturation of skies and such... here's a full run down, with sample pictures:
    Polarisers - a guide to using polarizing filters
  11. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Actually it will have a negitive effect. Your sensors filter already has UV or, AA filtration. Clears will not degrade the image if you get the Multi-Coated filters to kill glass reflection. Circular Polarizers are great for killing haze at the edge of the sky and, reflection on shiny objects.
  12. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Can only repeat whatever has already been said. I use GOOD UV filters on all my lenses for protection. Why UV than clear glass? Cost-benefit. UV are optically clear, but produced in greater numbers and thus cheaper. You gain no optical benefit. You only get optical degradation if you use a cheap filter (no anti-glare coating).
    Polarisers are different beasts entirely. They are used for artistic effect, and should be part of every landscape photographer's arsenal, although they could be used for a myriad of other things as well.
    Wrong. Digital sensors both CMOS and CCD are not natively UV reactive. You are right that there is an Anti-Aliasing filter on the sensor already, but this is to stop Aliasing effects of the Infrared range not the UV range. The only filtering on CCDs are optical Low-Pass Filters which filter out around ~780nm (well into the deep red) to the mid-InfraRed region. This varies with the sensor, but when this filter is removed all images come out reddish.
    Long story short no performance is lost at all as a result of blocking UV unless it gets too close to the purple end of the spectrum. But since the original UV filter was only blocking extreme instances of UV in cases of snow or beach photography, they are all well out of the visible range anyway, and thus appear perfectly clear.
best all around lens filter
best all around lense filter
best all round lens filter
best lens filter for beach
best lense filter uv or polarizer
polarized vs uv lens filter
polarized vs uv lense filter
uv lense
what is the best lens filter for beach
what lens filters are a nessecity
