beginning attempt at infinity backgrounds - C&C
Discussion in 'Photography Beginners' Forum' started by floatswitch, Jul 21, 2010.
  1. floatswitch
    floatswitch TPF Noob!
    Jul 13, 2010
    15
    right outside of washington dc
    so i was reading this tutorial from this blog about making a light box with stuff you have lying around the house. so i gave it a try, here's a result using it outdoors under sunny conditions. what do u think?
    [​IMG]
  2. MHRISH
    MHRISH TPF Noob!
    Mar 30, 2010
    72
    mississippi
    I think the results from the light box were good as far as lighting and exposure. I am not so sure about the composition though. I am wondering what it would have looked like if the tops of the bells had not been cut off. I am just a beginner though so I am interested in what some of the more experienced posters think.
  3. Dieselboy
    Dieselboy TPF Noob!
    Jul 20, 2010
    71
    Philadelphia
    Photos of the light box?
  4. floatswitch
    Jul 13, 2010
    15
    i'll take some here in a bit when i get home and post them up. it's basically just a cardboard box, you turn on its side open end facing you, cut square holes in the (now top) and two sides. replacing them with tissue paper (like from presents tissue paper). tape in a white backdrop on the inside. i used one of those rolls of paper from ikea for the backdrop.
  5. canonguy12
    canonguy12 TPF Noob!
    Jul 13, 2010
    54
    KY
    Get the idea from strobist floatswitch?
  6. white
    white TPF Noob!
    Mar 7, 2010
    1,131
    7
    I think this would look good in b&w with the contrast upped. Can I edit it?
  7. KmH
    Apr 9, 2009
    40,744
    5,588
    Iowa
    A pack of these work too, and can be used separately as reflectors.
    StaplesĀ® White Foam Boards, 20" x 30" | StaplesĀ®
    One for the bottom, one for the back, one for a side.
    They are what I used to make several images like this, but made inside with speedlights and umbrellas for lighting. I didn't attach the 3 pieces of foam board to each other. The image below only has the bottom and the back in it. The 3rd piece of foam board is to the left acting as a reflector:
    [​IMG]
  8. floatswitch
    Jul 13, 2010
    15
    yep that was the site.
    here's the snapshots of the box, as you may notice under the box i have a red tissue set, i'm planning on just playing around to see what lighting i can get out of diffusing other colors than white.
    [​IMG]
    [​IMG]
    @white, like this?
    [​IMG]
    @MHRISH,
    [​IMG]
  9. MHRISH
    MHRISH TPF Noob!
    Mar 30, 2010
    72
    mississippi
    Thanks, I like the uncropped one better, but they or both very good.
  10. canonguy12
    Jul 13, 2010
    54
    KY
  11. sarahjohn63
    sarahjohn63 TPF Noob!
    Jul 20, 2010
    4
    sarahjohn63
    I have also same as this boxes. When we capture any photos then it helps to take pictures and gives a very good reflection. I arraged it upper side of room because I think It is great place.
  12. white
    white TPF Noob!
    Mar 7, 2010
    1,131
    7
    Yeah I like the b&w. I'm curious to know what you think, though.
