Canon 50mm 1.4 Focus Troubles
Discussion in 'Photography Equipment & Products' started by DReali, Dec 28, 2009.
  1. DReali
    DReali TPF Noob!
    Oct 30, 2008
    293
    Switzerland
    BIG Troubles! I was sitting on a bench outdoors last night when i decided to take out my camera and take a photo of my friend.... for some reason the lens can now only focus somewhere between 3m distance and infinity, I can't focus any closer than 3m!:grumpy: I dont believe it was due to the cold because I had been outside for at least 2 hours before I took the camera out of my bag. I have a waranty on it as its NEW (super:grumpy:) but I was just curious if anyone has had this problem and ever so slightly hopeful that someone would tell me "yea dont worry about it, it'll just fix itself in about 42 minutes"
  2. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    If the problem still exists, and it is under warranty, I'd send it in.
  3. DReali
    DReali TPF Noob!
    Oct 30, 2008
    293
    Switzerland
    thats my plan, but for the moment i'm out of the country and have to wait a month before i can take it back to the shop. i was just wondering if this was a common problem with this lens or any others. Has anyone else had their focus mechanism block before?
  4. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Only thing I can think of is maybe is was over lubed at the factory, and the lube got thick in the cold. You should still be able to manually focus throughout the range though.
    Even that seems unlikely though...
    Is it working now (at room temperature)?
canon 1.4 50 mm focus stuck
canon 50 1.4 focus problem
canon 50 1.4 focus ring stuck
canon 50mm 1.4 focus
canon 50mm 1.4 focus issues
canon 50mm 1.4 focus problem
canon 50mm 1.4 focus ring stuck
canon 50mm 1.4 focus stuck
canon 50mm 1.4 stuck focus
canon 50mm focus stuck
