Canon FTb help
Discussion in 'Beyond the Basics' started by Palmag, Apr 5, 2004.
  1. Palmag
    Palmag TPF Noob!
    Apr 4, 2004
    11
    Australia
    I recently aquiered a Canon FTb, I have never used a manual camera, so I got stuck into the manual. I took some test photos and they came out ok but not great, they came out with a yellowish hue.
    I used a fuji film ISO 400, from what I could gather by reading the manual I matched aperture? (the needle with the circle at the end) to the light intensity needle. Is this correct?
  2. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    My brother has a n Ftb and if I remember correctly the needle is the light meter and you match it with the needle with the circle on the end of it. That one is moved by adjusting your shutter speed and/or your arperture.
    Great camera.
  3. Cuervo79
    Cuervo79 Guest
    yelow hue also comes out because of your light source, if its indandecent, if its neon its greenish hue
  4. Palmag
    Palmag TPF Noob!
    Apr 4, 2004
    11
    Australia
    Thank you for your replies,
    My question regarding the needle is, once the light meter needle is on, which device do I use to match the needle with, the aperture (fstop?)or the film speed, because either one of these gauges moves the needle up and down.
    Also what film speed is good for indoor and outdoor photography?
    thanks in advance!
  5. Cuervo79
    Cuervo79 Guest
    well first of all both would make the nedles move, now unles you want to push the film, the only ones I would use would be the aperture and the time... not the ISO of the film.
  6. Palmag
    Palmag TPF Noob!
    Apr 4, 2004
    11
    Australia
    Yes the ISO stays put, I normally use ISO400, what I ment was the time, when do I know to keep the time and only move the aperture, and do I keep the apreture and move the time, under what circumstances?
  7. Walt
    Walt TPF Noob!
    Feb 12, 2004
    1,054
    BC
    First of all 400iso is a good all around speed to use. As far as changing shutter speed or aperture is concerened, it depends on whether stopping action is more important or depth of field. Best thing to do is get a basic book on photography that gives a good clear overview of these functions.
  8. drlynn
    drlynn TPF Noob!
    Sep 19, 2003
    722
    In the Basement
    A good rule of thumb, if you're holding the camera instead of mounting it on a tripod, is to keep your shutterspeed to at least the focal length of the lens.
    If you're shooting with a 50mm lens, then try to keep your shutterspeed to around 1/60 or faster. This will help minimize blur caused by camera shake.
    So, to match your meter needle to your exposure needle, change shutterspeed or aperture accordingly to keep your photos sharp.
  9. Palmag
    Palmag TPF Noob!
    Apr 4, 2004
    11
    Australia
    Thanks for the advice, say I'm holding the camera and shooting my subject at about 1.5 to 2 metres away, I set my shutter speed to 1/60, turn on my light meter and match the light meter needle with my aperture needle?.... am I in the right track?
  10. Cuervo79
    Cuervo79 Guest
    that would be adjusting it by aperture I recomend to use the double the focal length just to be sure, use the other rule if you have little light, if you do the reverse, put an aperture and adjust by time.
  11. Palmag
    Palmag TPF Noob!
    Apr 4, 2004
    11
    Australia
    What do you mean double the focal length?, how do I do that?
  12. Cuervo79
    Cuervo79 Guest
    To minimize camera shake in the picture someone said to get at least the time the same as the focal length, lets say if its 50mm you go 1/60 I recomend double the focal length meaning 1/120. I meant the time
canon ftb camera outdoor settings
canon ftb ql camera light meter not working
how to change the shutter speed canon ftb
