let's say we have a silver bmw and i wanna make it look as cool and sleek as possible- like in the ads, lots of reflection and sprakling..
i am limited to 1 strobe with a pocket wizard- what can i do?
You can leave your camera on a tripod, make your shot then reposition the strobe and make another shot (as many times as you want) then combine them in Photoshop.
You can borrow a flash or 2 from friends to make your shot.
You can possibly rent some good lighting from a local camera shop.
Take the car to a well lit parking garage.
This wouldn't work because you are not pointing the strobe head directly at the car. You'd want reflected diffuse light to do most of your work and that would require using very large light sources (bigger than the car). If you were to use smaller light sources and try to combine the images in PS, I have a feeling it would look blotchy.
what about putting the camera on a tripod, the car against a sunset and then doing 3 shots. all 3 shots exposed properly, (something like 1/200 F4.0 - flash at 1/16th power), and firing the flash at the left side, front and right side of the car.
is it possible in any way to auto merge these 3 shots in post?
Sorry. I guess Lesson 1- How to shoot cars and big reflecting objects on location | Manfrotto Experience is the only way you will be able to photograph your car.
actually i've already read that article a while back, and he does way too much processing for my taste, lighting everything separately so much that it makes my head hurt thinking about it..
right kkamin, that first proposal was a bit unthought and dumb.. what about an umbrella so far away that i perfectly light the entire car in just one take? that might work..
