"clean dust" on scanned photo
Discussion in 'Graphics Programs and Photo Gallery' started by love0715, Mar 30, 2006.
  1. love0715
    love0715 TPF Noob!
    Feb 13, 2006
    4
    You will see lots of dust especially around my tuxedo area on this photo:
    http://i8.photobucket.com/albums/a10/tchan03/scan0018B.jpg
    The dust comes from the scanner (not my actual tuxedo)
    I scanned this 4x6 photo on HP scanner, the scanner surface inevitably has some dust.
    What features on Adobe ImageReady/Photoshop can i do to remove the dust? Please explain in details if u can.
    Thanks
    Terence
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Try the 'dust and scratches' fliter in ps... in the filters menu :mrgreen:
  3. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    Other methods could be the healing brush (band-aid) or the clone stamp. With either one, use a small brush size then sample an area close to the spec and then click on the spec. This method will take much longer, but you don't affect the whole image like a filter will.
  4. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    thanks mike, i came back to add that stuff but you said it for me :thumbup:
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I would run the dust and scratches filter, as mentioned, at 1 pixel, on a duplicated layer. You can mask off any areas you don't want affected.
  6. jeroen
    jeroen No longer a newbie, moving up!
    Oct 1, 2005
    1,132
    83
    Amsterdam, The Netherlands
    I wouldn't use a filter but use the clone stamp instead. That would leave everything else untouched...
  7. TRoskell
    TRoskell TPF Noob!
    Apr 5, 2006
    6
    The only problem with using one of the filters (like dust and scratches) is that it will also blur the rest of you picture, so afterwards to sharpen it up trying using the unsharp mask filter in photoshop.
    The clone tool as suggested before is a good way too.
  8. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yes, like matt said, if you've got the filtered image on a seperate layer, you can mask off the areas that you dont want the filter to touch. I personally wouldn't recomend using the filter, and then using the unsharpen mask on top of it... you are likely to produce pixel distortions.
  9. siorai
    siorai TPF Noob!
    Mar 10, 2006
    38
    Personally, I always crank the zoom up to between 200-400% and use the clone stamp. Sure, it's tedious and time consuming, but I end up with what I feel are much better results.
  10. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I second that.
  11. JTHphoto
    JTHphoto TPF Noob!
    Jul 22, 2005
    4,387
    73
    Phoenix, AZ
    I third... :thumbup:
    takes awhile, but i've had the best results that way too...
clean dust in scanned images
dust on scanned pictures
dust removal scanned photos
how to remove dirt from scan photo using photoshop
how to remove dust from scanned photos
photoshop removing dust from photos
remove dust scanned photos
removing dust from scanned images
