Composition for Cropping
Discussion in 'Beyond the Basics' started by woodsac, Dec 5, 2005.
  1. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    How does everyone else handle this? You envision a shot, take the time to set up, properly expose, and compose the shot the best you can within the viewfinder. You go home, process the shot...and it's beautiful. Success!
    But then someone wants a 5x7 or 8x10 print :er: Now, once you crop, to fit the print size, you risk loosing the combined strong points of the composition. Now if you're printing yourself, you can scale to print. But, when I send out to mpix or anywhere else, I have to crop the image.
    Is this just something I have to deal with, or is there a way around it? It's just frustrating :confused:
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Started using a 35mm slide mount on a 50mm section of toilet roll! Now I see the world as a standard lens!! Visualisation comes after time and experience, the viewfinder just helps me check I haven't chopped a bit off or included a wrong bit!
    Rob
  3. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    Sorry Rob, but I don't understand what you're saying? I am framing and photographing exactly what I want to see, no problem there. But in order to reproduce that on a small print, I lose a significant amount of the image.
  4. zedin
    zedin TPF Supporters Supporting Member
    Jun 17, 2005
    349
    5
    Irvine, Orange County, CA
    I guess the only suggestion is to keep the sides of your print where they are not required to make the photo. They can enhance it but keep in mind that for each picture you might lose a strip from 1 or both sides due to a crop. If you are worried where the crop is going to be either pre-crop it (if digital) or order a full size (like a 8*12) and crop it yourself.
  5. Marctwo
    Marctwo TPF Noob!
    Aug 19, 2005
    485
    10
    B'ham, UK
    Most shots I do will work in whatever format I want; 12 x 8 (3:2) to 10 x 8 (5:4). In this case I just process the image at 3:2 with room for cropping on the sides when necessary.
    However, sometimes only one or the other works so I'll simply not even consider doing a crop I don't like.
  6. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    Thanks zedin. I pre-crop everything before I send it out.
    Marctwo, maybe the ratio is my problem (lack of experience)? Of course, the bigger the print, the more image I save. 11x14 and 16x20 come out great. But, like I said, the smaller 8x10 and down, I have to physically crop out parts of the image in order to make it fit.
    Maybe that's what I need to consider. I just won't be able to offer some prints in smaller sizes ;) Thanks for the help.
  7. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,325
    102
    Poland, Sz-n
    Sorry woodsac but I don't get what you are talking about... why can't you crop it to the smaller sizes? you can always resize the prints... as far as I know there are a few "small" sizes of the prints with the same ratio as bigger ones...
  8. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    I think that is just something that comes with experience. If you think that you will need to make 5x7 or 8x10 prints (weddings for example)...then you leave some room in the composition for cropping. You could even envision the crop and shoot with that in mind.
    I find that I crop 90% of my shots in post processing. Not that I'm careless when I'm taking the shot...I just like to have a bit of margin to work with and I like to have the option. There is nothing worse than going over the shots and wishing that you had taken a step back or zoomed out on every hot.
  9. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    If you're shooting with 35mm film, you can construct a manual viewfinder using a 35mm frame sized hole and a tube of the same length as your lens - this is an old trick to make a manual viewfinder cheaply. It makes you look stupid though.
  10. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    I always design my images for a set image size. If people want my pictures a different size then they can want. If they don't like it that's their problem.
    People didn't go to Picasso and say 'love the painting but could you do it a bit smaller?' ;)
  11. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    OK...so I wasn't missing anything. They're just a bunch of cheap bastards that only want to pay for a small print, but with everything that the big print has on it :lmao: j/k
    Rob, I shoot digital, but that makes perfect sense now that you explain it :thumbup:
    Mentos, I can always crop it to a smaller size, but a 5x7 crop only allows for so many pixels of height and length. I couldn't crop a 36 inch 10800 pixel pano to 7 inches and still have the entire scene. Does that make more sense?
    Thanks for all the help!
  12. Marctwo
    Marctwo TPF Noob!
    Aug 19, 2005
    485
    10
    B'ham, UK
    If you have a 16 x 20 image and you want to do an 8 x 10, you need to resize it rather than crop it. As they are both the same aspect ratio (4:5), you won't lose any of the composition - you'll just lose some detail as you'll be using less pixels to make the same image.
    I've never used one of those printing services but I think most of them can do the resizing for you. Of course, you'd have to speak to them about that.
composiotion verses cropping
