Correcting the horizon line, straightening ...help
Discussion in 'Graphics Programs and Photo Gallery' started by MostlyDigital, Mar 20, 2005.
  1. MostlyDigital
    MostlyDigital TPF Noob!
    Feb 9, 2005
    164
    New Jersey
    How do I correct the horizon line in a picture? (make the picture look like its level, and straight) Do I move the whole picture till the horizon is straight? If so how is this done? I tried to figure it out and I searched the internet but found nada. Please help, thanks :)
  2. SWFLA1
    SWFLA1 TPF Noob!
    Aug 23, 2004
    241
    use the rotate command - mine usually needs rotated by 1 degree... you can experiment and see what you're norm is....
  3. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    If you are using photoshop, it's probably easier to duplicate the layer - drag the background layer down to the new layer icon in the layers palette, then ctrl + t right click and choose rotate, then rotate your pic until it's straight.
    You'll then need to crop out the empty parts of the pic so that you don't have weird looking edges.
  4. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    5
    Pasco, WA
    If you're using PS you can right click the eye dropper in the toolbar and select the measure tool. Start at one end of the horizon and draw a line to the other end.
    Go to Image|Rotate|Arbitrary and the image will automagically align itself properly (assuming you drew the line correctly).
    Alternately, if you can lay a grid over your pic you can rotate it manually by trial and error.
    In either case you need to crop the image after rotating it.
  5. Kent Frost
    Kent Frost TPF Noob!
    Jan 27, 2004
    572
    21
    Springfield, MO USA
    This is how I typically do it:
    1. Open the image.
    2. Type F to go to the view where you can have some room to play with the image.
    3. Select the entire image with the marquee tool or by typing CTRL+A.
    4. Go to EDIT, then TRANSFORM, then ROTATE. You will see the box appear around the image.
    5. Using the mouse, place the cursor near one of the corners and rotate the image until it is as straight as you'd prefer.
    6. At this point, you'll notice that the corners of the image will have slivers of triangles of whatever the background color is. To eliminate that, zoom in to one of the corners and select the part of the image that does not include those slivers.
    7. Go to IMAGE, then CROP.
    8. (Optional) If you'd like to make the image the same size as it was, go to IMAGE, then IMAGE SIZE, and resize.
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I turn on the grid so that I have straight lines for reference, then rotate the image.
  7. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I use the measure tool and let photoshop do it for me. Be aware that you will probably have some barrel distortion.
  8. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,324
    102
    Poland, Sz-n
    hmm I rotate my head... then the pic is straight :)
  9. MostlyDigital
    Feb 9, 2005
    164
    New Jersey
    Thanks alot, got it :)
  10. Bob Fiske
    Bob Fiske TPF Noob!
    Mar 27, 2005
    20
    New Hampshire, USA
    Another way is to select the entire image with the crop tool, rotate from a corner until the horizon is straight, crop, select the whole image again, and move each side in individually until past the exposed canvas and crop again. This method is not precise with the second crop because the borders of the crop selection don't move in tiny increments but this method is quick and easy and good enough for most shots. Of course, with PS there are always 10 right ways to do anything!
