Cropping/Resolution
Discussion in 'Graphics Programs and Photo Gallery' started by ang, Feb 2, 2005.
  1. ang
    ang TPF Noob!
    Jul 23, 2004
    58
    Massachusetts
    When you crop a photo in photoshop, does this lower the resolution in the picture?
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    It lowers the pixel resolution, yes. If you want to change the print resolution (pixels per inch), you have to do that in image/image size.
  3. Rogue Monk
    Rogue Monk TPF Noob!
    Jan 18, 2005
    98
    Vancouver, Canada
    If the resolution remains the same (ie. 300dpi before and 300dpi after), then the only thing changing is the physical dimensions (width and height--which can be measured in inches, cm, picas, or pixels).
    If after the crop, you want to enlarge the new picture to the original dimension, then yes, you are losing resolution.
  4. ang
    ang TPF Noob!
    Jul 23, 2004
    58
    Massachusetts
    Rogue,
    When I enlarge the photo AFTER cropping it down, the resolution (pixels/inch) under the image command stayed the same??? What you said made sense to me, but now I'm confused.
    Assuming you are correct, can you regain the original resolution after enlarging a cropped photo?
    thanks
  5. Rogue Monk
    Jan 18, 2005
    98
    Vancouver, Canada
    What program are you using?
    If its Photoshop, then you have to uncheck "resample image" before changing the dimensions. A "3-prong fork" should connect width, height and resolution.
    [​IMG]
    Now, changing any of these measurements directly affects the others.
    You can still resize while "resample image" is checked, but the resolution won't change with dimensions. This means the image will degrade with the enlargement--maybe not so much that you notice, but it will.
    resolution (or quality) will always decrease as size increases. If you have an image that's 5*4 and 300dpi, taking it to 10*8 will make the dpi 150.
    Does that help clarify it?
  6. ang
    ang TPF Noob!
    Jul 23, 2004
    58
    Massachusetts
    Rogue,
    I do have Photoshop. Thanks for the clarification.
    ang
does croping change resolution
does cropping a photo change its resolution
does cropping a photo reduce the resolution
does cropping a picture change the resolution
does the resolution change when picture cropped
why does cropping a photo change it
