D300 ISO settings
Discussion in 'Photography Beginners' Forum' started by crazyy, Mar 30, 2009.
  1. crazyy
    crazyy TPF Noob!
    Mar 2, 2009
    11
  2. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    *I think* it's because Nikon uses ISO 200 as it's native ISO setting (on some cameras anyway). That is their clean, unaltered signal from the sensor. Like any digital camera, higher ISO settings are achieved by amplifying the signal...which causes distortion, which is why we get digital noise at higher ISO settings.
    But when it comes to a lower ISO...*I think* that the camera just uses an ISO 200 signal and underexposes it one stop. Of course, the metering is adjusted, so you don't actually get an underexposed shot...but I think that you would get the same noise/image quality as ISO 200.
  3. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    That's my understanding too.
    To the OP;
    On most Nikon models their native ISO is 200. This means to get to ISO 100 the processor alters the image data which will introduce noise. It's not much usually, but it does none the less. It's the same going up the ISO scale. When you change the ISO setting on your camera you're not changing the sensitivity of your sensor to light you're really telling the processor how much to amplify the signal. This too introduces noise.
    As a side note, your camera will produce the best images set to its native ISO setting. For me, I shoot at ISO 100 (my cameras native ISO) when I can to maximize the image quality.
    To get to ISO 50 on my Canon I have to "expand" my ISO in my setup menu which then makes ISO 50 available.
    I suspect Nikon chooses ISO 200 as their native sensitivity as this will likely give cleaner images at higher ISO settings... at least by one stop compared to the competition. The trade off is not having ISO 100 available unless you enable it and it then introduces processing noise at that lower ISO. That's just a guess though...
  4. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    This is the same idea as the HI-1 (-2, -3) settings on some Nikons -- it's similar to ISO 3200, 6400, etc. but isn't actually that real ISO setting -- it's taken at a lower (or higher) ISO, and processed in-camera, which gives more noise than usual.
  5. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    A bit more detail if it's helpful... whatever the numeric ISO numbers that are actually displayed are on your camera, those are actual ISO settings. The LO and HI and other non-numeric ones are non-native. I understand them to be interpolated in some way. The specifics of how they do that I am unsure of.
    The general advice I have been given is to try to stick to the real numbers and avoid the interpolated ones.
    Also worth noting that not ALL Nikons start at 200. The D200 has a low point of ISO100, for example. (I was displeased that it went up to 200 on the D300, but I suspect that's because of the sensor change)
  6. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
d300 iso
d300 iso settings
d300 native iso
iso setting for d300
iso settings on d300 camera
nikon d300 iso setting?
nikon d300 iso settings
nikon d300 native iso
nikon d300 photos with iso settings
on nikon d300 best settings night photography
