D70 flash sync speed
Discussion in 'Beyond the Basics' started by Patrice, Dec 6, 2006.
  1. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    A while back I was playing with the D70 set to manual with a Metz 45CL connected via a simple hot shoe adaptor. What really surprised me is that the camera and flash sync was flawless up to 1/4000 sec. When I test this with the D80 or the D200, it does not work. Is there a fundamental difference with the D70 shutter?
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The D70 uses an electronic shutter, which basically means there is no shutter. Power is turned on and off to the sensor instead of using a shutter. The actual x-sync speed of the D70 is 1/500, because this is the fastest reliable shutter speed, but you can technically use any. The D80 and D200 use traditional focal plane shutters, and anything faster than 1/250 is faster than the duration of the flash. You will see the shutter curtains cutting the image.
  3. Patrice
    Dec 6, 2006
    2,392
    381
    Thanks Digital Matt !!
    I think I'll keep the little beastie for a while yet and play some more.
