So many questions, so little time to respond. It's Saturday AM, gotta get out to Silver Creek Falls soon.
I've used double and even triple diffusion at times over the years. I am a huge fan of Speedotron snap-on mylar diffusers for metal parabolic reflectors, and often use 1,2, or 3 of them over 11.5-inch or 7-inc metal reflectors on my flash units. Diffusion can come in many forms, not just from panels.
I like umbrella boxes in which the light hits a DULL-colored, white VINYL interior (not the shiny rayon type stuff), and then goes through THIVK ripstop nylon. Lastolite Umbrella Box...thius is why the quality of the light is better than the cheaper, $29 per pair Steve Kaeser Enterprises umbrella boxes. This is double diffusion...once off the inside, again thru the fabric...doubly-diffused....Ad a mylar diffuser over the flashhead and it's triply-diffused light...
Panels/scrims and fabrics/silks/mesh can all be used as second diffusion sources, and there are MANY setups....you can even use two fabrics/silks over a panel (scrim) and shoot raw light off to one side, and force the other part of the beam to come thru the fabric(s) so it is diffused. Limitless arrangements possible using a diffuion scrim aka a panel.
This type of lighting has been covered in the old Dean Collins "Finelight" videos; search YouTube for some SUPERB videos. Diffusion can be used to both increase the size of a light source and/or to reduce its hardness(its shadow-causing potential) or reduce its specularity (look it up). Diffusing light can be done with opal glass, mylar, metal or fiberglass screening,tracing paper, coffee can lids, Visqueen window plastic, and factory-made stuff like TuffSpun (a Fibreglas [trade name Fibreglas,one s,e before g] material, and so on. Same with ripstop nylon, thule, silk, gauze, whatever.
Diffusion and using more than one diffuser has a set of optical rules. The closer to the panel the light is, the more it diffuses; the farther away the light is from the diffusion panel, the harder the light is. The material itself also has an effect: window screen or wire diffusers diffuse LESS than say, ripstop nylon material does, at the same setup. Larger panel = larger source =softer liught at closer distances. Beyond 25 feet or so, the physicval size of the source of the light becomes almost the same in most cases.
Does difusion enhance fine detail? Uh...not necessarily; Usually detail's appearance is due to shadow,specularity, and contrast, so in general, I think saying diffusion "enhances detail" is not the right way to state that. HARD, crisp light raked across wood can show "detail", same as it can in hair....so, I have no idea who said that diffusion enhances detail, because that's not an accurate statement; I think it's like saying, "Hard liquor enhances sexual performance."
Ummmm...yes. And no. It all depends on how it is used. Not sure why diffusion would enhance color saturation either...but it CAN allow you to under-expose things like color transparency film, which DOES appear to enhance color saturation. On a foggy, diffused-light day, color transparency film can be UNDER-exposed, a LOT, and can deliver deep,rich-looking 'chromes; I think perhaps the above idea is a holdover from film days.
Re:catchlights. If you have a BIG panel, a Dean Collins-like very big panel, say 72 x 72 inches, it CAN make catchlights disappear if the panel is placed close enough that the eyeball or product
reflects the entire panel's lighted surface. For example, put a P-22 panel 48 x 72 inches very close to a human; the panel can be so close that instead of a rectangular catchlight, what forms is a reflection that covers the entire eyeball's surface. SAME THING happens allllll the time with wine bottles, or jewelery, or Plexiglass tables: move the panel into CLOSE proximity to these items, and the "catchlight", the shaped-one, disappears, and is replaced by a big, honking overall,
shapeless, lighter-colored reflection...
On products...see the Five Things You Can Do With Just One Softbox video on YouTUbe, by Tony Corbell....watch his jewlery segment in that video, you'll see what making the liught soure VWERY large in relation to the subject, can do.
Disatance from source to panel: No rulkes. Close=softer, farther=crisper. Size of original and modifier size and nature both affect the relationship and effect. A metal 7 to 16-inch diameter refelctor works wayyyyyyy differently than a 28-inch softbox, when shot thru the same sized panel. NO fixed rules: depends on desired effect,lights,diffusion materials.
- If I'm using my large octabox as the primary, and diffusion panel in between, I'm assuming it will pretty much eliminate catchlights. Should I try a second light to supply the catchlights or just add them post? Seems like that might be the easiest
I'm not sure that's anywhere near correct. It depends on how close the panel is. Dean Collins:
our job is to create and place the diffuse highlight. Post-applied catchlights can be done pretty easily these days....buuuuut...what does the lack of catchlight reveal on the subject? How close the panel is and how big it is will determine the catchlight and the diffuse highlight patterns.
There WAS an internet-sold book on "Scrim Lighting", some years back.... The Dean Collins Finelight videos are worth their weight in gold. Search them out on YouTube.I downloaded every one I could find.
