Mully
- Joined
- Jul 23, 2012
- Messages
- 3,066
- Reaction score
- 788
- Location
- Mt Ulla, NC
- Can others edit my Photos
- Photos OK to edit
Charlie ...you are such a good boy....looks nice now....OP nice capture.
Wackii... if you metered on the Egrets, you could have probably gone a 1/2 to a full stop of + EC (your Exif states you were spot metering).
I still find your edits a little underexposed. Laptops are hard to work with.. as any change in the display angle really changes what you will see.
I did a edit (just brightness) on my calibrated IPS panel... should be close. Did a curves adjustment with the white dropper on the brightest part of the bird...
Your edit is on top.. mine is on bottom
Thanks Charlie for the edit. Your edit looks much better. I like the white adjustment. It makes the Egret pops out. Comparing your edit and mines side by side, now I see that my edit is underexpose. I still need to mess around with light room. By the way, when taking pictures of birds like these, is using "spot metering" correct? I have a Nikon D5100 at the moment (thinking of getting the Nikon D7100 when it's out) which has Matrix metering, Center-weighted metering, and the spot metering. What settings do you guys use?
Thanks,
