One thing to keep in mind with buying filters though is to buy the size of your largest diameter lens and then buy step filters to fit all your other lenses. It's much cheaper than buying multiple sizes of each filter.
I've heard this before but what about lens hoods? I'd imagine you can't use one if you have a larger filter on your lens...
I also remember reading that the only filter you can't mimic in post processing is a polarizer... Is that true?
Yeah the Nik is pretty good but not close. BUT! You can save the picture you used the CP on and, then keep polarizing it and, saving, repeat, till you get it fairly close. I like my CPol for alot of shots and, use it more that my other filters. That and my ND. I also have a Blue Polarizer for some of the areas here, it really brings the reds out in shots.Not strictly speaking, the Nik Color Effex series has a polarizer which under certain conditions doesn't do a bad job. It's nothing like using a real filter would have been, but it's acceptable in a pinch.
