First time officially out! Networking Party Shoot.
Discussion in 'The Professional Gallery' started by CESTO, Mar 18, 2010.
  1. CESTO
    CESTO TPF Noob!
    Apr 3, 2009
    39
    Gear used:
    T1i
    18-55
    50 1.8
    430exii
    Fong Lightsphere Cloud
    was an all black room, maybe 10-11 foot ceilings, I used the cap for the fong, trying to bounce, but due to the room, i mostly used the fong as a soft box...
    It was tricky, as every shot required different positioning...
    Anything you see where I went wrong or could have improved on?
    Any suggestions or comments are appreciated.
    REAL Bizzness Shoot - a set on Flickr
  2. bennielou
    bennielou TPF Noob!
    Nov 27, 2009
    1,798
    171
    Dallas, TX
    They are fine, but a little dark I think. Curves layers are your friend. :) Just take the photos into photoshop, and bring up a curves layer. It's the little half white/half black thingie at the bottom of the layers pallet. Hit that button, and then grab the bar in the middle, and lift it straight out to the Left side corner. Just a little bit should do it.
    A tip for being is a dark room is to bounce off of a white shirt when possible. Under our black clothes is a white shirt. Silly, but it works.
  3. BuZzZeRkEr
    BuZzZeRkEr TPF Noob!
    Nov 26, 2007
    436
    Va
    I don't think these work too well, there isn't any ambient lighting and the one where you can see a background there are very harsh shadows cast by the subject and balloon. Your subjects in some are under exposed...keep trying.
  4. CESTO
    CESTO TPF Noob!
    Apr 3, 2009
    39
    thanks for the feedback.
    bennielou:
    i am going to try and tweak with the curves.
    never really did. the t shirt bounce i will also keep in mind when shooting.
    BuZzZeRkEr
    what would you suggest given the conditions?
    And the balloon shot, I wish i was on a better angle,
    but do you think it's that bad that i should not include in the set?
    Thank you!
  5. bennielou
    bennielou TPF Noob!
    Nov 27, 2009
    1,798
    171
    Dallas, TX
    Cesto,
    Would you allow me to pull the curve on a photo for you and show you how I did it? I would need a full res file. If you agree just send the photo to the contact section of my website.
    I really think it will help you.
  6. webmaster705
    webmaster705 TPF Noob!
    Feb 19, 2010
    70
    Pakistan
    Nice effort you just need to create some extra efforts just go in photoshop and change expression, and have some new shots i am sure new one will be best
  7. CESTO
    CESTO TPF Noob!
    Apr 3, 2009
    39
    Ummm... webmaster705...
    What? I didn't quite understand you?
  8. BuZzZeRkEr
    Nov 26, 2007
    436
    Va
    I'm not sure what the exact conditions were unless I were at the venue myself, however I find alot of photographers give themselves only 2 options......bounce the flash off of the ceiling, or go straight at 'em via diffuser/gary phong etc. I scout all of my locations prior to big contract shoots so I go in with a game plan which might of helped you. I've been in all kind of situations from having ceilings painted red, green, yellow to being in rooms completely painted black with super high ceilings and there has always been an answer. First tip would be is optimize your speedlight capabilities....point it in every direction possible....and yes even directly behind you. You can use your speedlight to bounce off of anything your environment...even people/walls mirrors etc. Use only manual modes to adjust your exp on the fly to compensate for your constantly changing environment. Go with an assistant to hold remotely controlled speedlights to capture rim lighting/dramatic lighting effects. This is all gained with experience and lots......lots of practice. If your going to advertise yourself as a professional, then make sure you have enough equipment, expertise, and experience to do the job asked and knock it outta the park.
  9. CESTO
    CESTO TPF Noob!
    Apr 3, 2009
    39
    Thank you, that was good advice!
    I should have checked the spot out first.
    That was the first time i used a flash other than the internal.
    Practice i will do, and the bounce off everybody and everything will definitely help me with my light direction understanding.
  10. fotograf biel
    fotograf biel TPF Noob!
    Feb 7, 2010
    48
    Switzerland
    Cesto,
    Just drag the shutter more. A longer shutterspeed will allow you to capture more of the ambient light and the flash will freeze your subject...use high ISO as well...
    I think this will improve your pictures!
