flash?
Discussion in 'Beyond the Basics' started by spicychicken, Jan 10, 2005.
  1. spicychicken
    spicychicken TPF Noob!
    Dec 27, 2003
    34
    nj
    ook.. i have a minolta x-300 with a vivitar auto thyristor 2800 (whatever the hell that means) that connects to my hotshoe and i have no idea how to use it! what do i set for my shutter speed to take into account the extra burst of light? if i put it on the auto setting, will it recognize the flash and compensate?
    the flash has asa and din information on the back of it with fstops but i don't understand it very much :( how sad. can you clue me in a little bit?
  2. tmpadmin
    tmpadmin TPF Noob!
    Dec 13, 2004
    876
    Buffalo, NY
  3. Big Mike
    Dec 16, 2003
    33,852
    1,817
    Edmonton
    A flash with an auto thyristor is pretty easy to operate.
    First find out your camera's x-sync speed. That is the fastest shutter speed that will work with a flash. Usually it's around 1/60 to 1/125 with a focal plane shutter.
    Now you put your camera into manual mode and set the shutter speed to the sync speed or slower. Set the same f-stop on the flash and on the camera.
    When you take a shot, the flash will read the reflected light and quench it's output when it thinks there is enough light to expose for the selected f-stop. You can adjust the shutter speed to control how much ambient light you capture. A longer shutter speed will expose more background, typically.
    Flash photography can be pretty confusing so you may want to do some reading.
  4. spicychicken
    Dec 27, 2003
    34
    nj
    thanks :D
