HDR questions
Discussion in 'HDR Discussions' started by myshkin, Jun 17, 2010.
  1. myshkin
    myshkin TPF Noob!
    May 8, 2010
    367
    26
    Lima, Peru
    Just curious, DO you guys PP some before creating the HDR? Do you turn into Tiffs or do you create HDR with raws?
    So far I create with the raw and then PP after the HDR is made
  2. bdbolin
    bdbolin TPF Noob!
    Mar 6, 2010
    20
    Usually I will create the HDR with the raw files and then just edit the final image.
  3. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    I tweak a few levels in lightroom, make into an hdr, then go back into lightroom and tweak some more levels. Haha.
  4. Scatterbrained
    Scatterbrained Been spending a lot of time on here!
    Apr 19, 2010
    2,181
    1,081
    Yucca Valley, Ca
    This. I set my WB and color levels on the 0 exposure, then copy the settings to the other exposures. Export as Tiff, combine the images and then re-import into LR to finish and convert to JPEG.
  5. myshkin
    myshkin TPF Noob!
    May 8, 2010
    367
    26
    Lima, Peru
    Seems like this thread should have more replies since everyone has to do some sort of process for their HDR. I guess this forum is just dead besides a couple of members fighting
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Whether or not you use the RAWs as your base depends a lot on how close to proper exposure your RAWs are to begin with. I often try my luck with the RAWs to save a bit of time and then go process them first to TIFFs if it didn't work out.
  7. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    correct a few issues in RAW; ie. CA, or spotting, apply the "fix" to all exposures in the series, save as TIFF, files. Move to the HDR software needed for the image. Save as TIFF and then make more creative decisions with PS.
  8. Brick
    Brick TPF Noob!
    Apr 3, 2009
    107
    Arkansas
    I use RAWs to create the HDR and then photoshop from there.
  9. stevegonsalves
    stevegonsalves TPF Noob!
    Apr 21, 2010
    9
    ny
    Personally, I will create the HDR with the raw files in HDR Darkroom and just edit the final image in CS4.
