HELP! Virtual Tours?
Discussion in 'Beyond the Basics' started by manaheim, Jul 25, 2009.
  1. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Hi all. I'm making an aggressive play to get into residential real estate, only at much higher prices. :)
    Anyway, obviously the RE market is all hubbly-bubbly with virtual tours, but what the heck is a virtual tour? I mean, I can make a panorama easily enough... but in my initial research, it seems like these things range from a single panorama run through SOME kind of tool... all the way up to a 20 point run-through of a house with arrows on doors that you can click and stuff?!
    I would really appreciate if anyone could help me understand the options here... what folks charge for these services... what is the more usual/accepted method of doing these, etc.
    THANKS!
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    I was about to recommend that the OP asking Manaheim. Oops.
    I think it is whatever the realtor wants it to be, as in a walkthrough of the house, such as an exterior pano, and then a walkthrough, similar to Google Streetview, I think there are a few software options, something that needs more research.
    Good luck.
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  4. c.cloudwalker
    c.cloudwalker TPF Noob!
    Jun 15, 2009
    5,394
    405
    An American in Europe
    Well I just googled "real estate walk through photo software" and there are a few things there.
    As for rates, sorry, no idea but I'm sure it is area related like a lot of things. Try and find an agent, friend of a friend type thing, who could tell you.
    The other way to do that is figure out who does this kind of photo in your area and call them. Just tell them you're going to put your house on the market FSBO and want to know what it would cost... I've used this technique a few times for different things and it works very nicely. ;)
  5. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
  6. manaheim
    Sep 2, 2005
    14,394
    3,262
    Hi Jon. (I was hoping you would chime in here) I do full panoramas with my regular tripod head all the time... I'm not entirely sure how this one is necessarily critical? You probably know something I don't, though.
    What software do you use?
  7. Jon_Are
    Jon_Are TPF Noob!
    May 12, 2007
    644
    Hey Chris,
    Well, I don't actually do them (yet), so I've not really looked into the software (yet).
    Apparently you need the Panosaurus, or something similar, because (lifted from the site):
    A standard camera tripod is designed to hold and rotate a camera around the tripod mounting hole of the camera. This hole is located arbitrarily somewhere on the camera body. However, to take accurate panoramic photos it is important that the camera be mounted and then rotated around what is called the optical center (sometimes called the nodal point or entrance pupil) of the camera's lens. This ensures that optical distortion, called parallax distortion, will not be introduced into your pictures before they are then stitched together using computer software. Many people use panoramic tripod heads to not only take wide vista shots, but also to take 360 degree QTVR photos and photo mosaics (multi-row megapixel panoramas).
  8. manaheim
    Sep 2, 2005
    14,394
    3,262
    errmmm...
    Or you could just use photoshop which fixes the distortion completely. :)
    Not to mention rotating it around it's optical center shouldnt remove distortion... though it may minimize it.
    Honestly sounds like MAJOR bs to me. I might ask for some more opinions on it. What I can say is a good panning head will certainly make life a bit easier, but not by any remarkable level from what I've seen. I could be wrong.
  9. c.cloudwalker
    Jun 15, 2009
    5,394
    405
    In my area there are ads on craigslist for photographers to do this kind of work all the time and they all require specific tripod heads.
    But we are talking about companies that will probably send anyone in the field who owns a DSLR and the right tripod head, and is willing to sit through their "2-hour-over-the-phone-training-session." The companies do the PP work so it's probably only a question of making their lives easier.
  10. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
  11. manaheim
    Sep 2, 2005
    14,394
    3,262
    You know, now that I'm thinking about it, all my panoramas have been of far-off scenes. I think I need to do some experimentation at home tonight.
  12. harleyrider
    harleyrider TPF Noob!
    Jul 16, 2008
    94
    cant you just take one pic of each room two for big rooms and thats your tour,click a button on a online ad and it takes you though the house room by room.
    is this a tour to?
