Help With C&C
Discussion in 'Photography Beginners' Forum' started by signal5alpha, Mar 1, 2010.
  1. signal5alpha
    signal5alpha TPF Noob!
    Feb 3, 2010
    Near The Edge Of The Earth
    [​IMG]
    I took some photos at Bodega Bay in Northern California, I have a Nikon D3000 and I left the ISO on 400 instead of 100 for a fairly sunny day.
    I set the camera on P and the shutter speed was I think about 1250 and the Apeture was about 5.6.
    The rocks seem too dark and the sea seems too bright. Can you help me? Thanks.
    Jim
  2. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    The whole picture is badly overexposed, rocks too.
  3. mrmacedonian
    mrmacedonian TPF Noob!
    Aug 29, 2009
    370
    4
    Columbus, OH
    Camera Maker: NIKON CORPORATION
    Camera Model: NIKON D3000
    Image Date: 2010:02:28 20:32:17
    Focal Length: 85.0mm (35mm equivalent: 127mm)
    Aperture: f/9.0
    Exposure Time: 0.0008 s (1/1250)
    ISO equiv: 400
    Exposure Bias: none
    Metering Mode: Matrix
    Exposure: program (Auto)
    White Balance: Auto
    Flash Fired: No
    Color Space: sRGB
    Bit fast on the shutter speed? Not sure but I think you should be able to effectively stop the motion of the water with a slower shutter speed. Also definitely always start with ISO 100 and then move up if it becomes evident its necessary. I think you could have dropped the ISO down to 100 and the aperture to about f/11 and still have used a slower shutter speed, but then again I'm not experienced enough to make that kind of call without experimentation, so consider that as well.
  4. er111a
    er111a TPF Noob!
    Jan 30, 2008
    1,896
    6
    Virginia
    here you go, I know its not the best but I gave it a try :)
    [​IMG]
  5. AJake
    AJake TPF Noob!
    Feb 26, 2010
    53
    Ohio, USA
    Quick question, and yes this is off subject, but how do you find this info without the OP posting it?
  6. mrpink
    mrpink No longer a newbie, moving up!
    Jan 8, 2010
    1,962
    328
    Cincinnati, Ohio
    EXIF reader... google it.
    best I could get it...
    [​IMG]
    p!nK
  7. er111a
    er111a TPF Noob!
    Jan 30, 2008
    1,896
    6
    Virginia
    does no one like my edit :(
  8. reznap
    reznap No longer a newbie, moving up!
    Feb 2, 2010
    2,410
    64
    Ohio
    Personally it's too bright for me, the highlights are blooming.
    mrpink's edit is badass though.
  9. er111a
    er111a TPF Noob!
    Jan 30, 2008
    1,896
    6
    Virginia
    I spent only 10 min on it, plus this pc I am on only has gimp :p
  10. Layspeed
    Layspeed TPF Noob!
    Oct 11, 2009
    307
    British Columbia, California & Philippines
    I agree p!nk's edit is really good for what the original was! The original shot is way overexposed in the background, but underexposed on the rocks. Usually it's difficult to get both. I've heard ND filter's can help. Or you could expose for the water, then bring up the exposure on the rocks in PP?
  11. matfoster
    matfoster TPF Noob!
    Feb 12, 2010
    722
    Nuneaton, Warwickshire, UK
    [​IMG]
    levels auto, increase mids input, reduce whitepoint output, sharpen 0.2/0.29, burn surf, dodge rock shadow.
  12. matfoster
    matfoster TPF Noob!
    Feb 12, 2010
    722
    so what? turn on GEGL, use 16 bit color editing, no difference.
