huh?
Discussion in 'Photography Beginners' Forum' started by StreetShark, Aug 11, 2007.
  1. StreetShark
    StreetShark TPF Noob!
    Mar 11, 2007
    219
    Well I was searching on henry's photo today and I was rather amazed to find a canon EF 28mm F/2.8 for just $300.00. Is this a good deal? and is this a good lens? I like shooting landscapes so im trying to find a good prices wide angle.
  2. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    Looks good to me, though im not positive, just remember the crop factor. So it wont actually be 28mm unless you have a camera with a full frame sensor.
  3. StreetShark
    Mar 11, 2007
    219
    Yeah I know so its about 45mm on my camera.
  4. photogincollege
    Aug 4, 2007
    706
    Yeah thats still a pretty wide angle. Hmm my old wide angle lens had was well it says f=28 MM but then another place on the lense says 52 mm, not sure which one. For 300 bucks even if you dont like it you could probably get a decent resale on it.
  5. I assume the 52mm means the width of the front end of the lens. You need to know that for such things as filters that you might want to screw on the front of the lens.
  6. I just wanted to learn more about the lens, to read some reviews and see what it's worth. Good reviews, and it sells for [ame="http://www.amazon.com/Canon-28mm-2-8-Lens-Cameras/dp/B00006I53T"]new at Amazon for $175[/ame]
    But I'm sure you've done your own quick Google search and have come up with the same info by now...
  7. StreetShark
    Mar 11, 2007
    219
    yeah I also read the sharpness is bad all the way up to f/5.6 or so
  8. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
  9. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    As JIP pointed out, $300 for a 28mm f/2.8 is far from a good deal, in fact it's a very bad one. $300 would be a decent but still not amazing deal for an f/1.8 in the same focal length, since that retails for under $400.
    As for wanting a wide-angle... honestly, I would not consider a 28mm on a APS-C camera a real wide-angle by any stretch of the imagination. As you say it's similar to a 45mm lens on a 35mm film camera, which is really not very wide at all, being pretty much the "standard" focal length rather than either wide or telephoto.
    For under $300 you could get the Canon 24mm f/2.8 instead... but even this would only be a very moderate wide-angle if used on the APS-C sensor. Personally if looking for a real wide angle then I would be looking for at least something around 18mm (as covered by a "kit lens" or standard zoom) or ideally something even wider.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  11. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
  12. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    First of all, Henry's doesn't have good prices...unless you buy from their E-bay store. I'll recommend B&H (link at the top of the page).
    Secondly, the Canon 28mm F2.8 isn't a good lens, that's why it's so cheap. It might be OK, when stopped down to F8 or smaller...but so is your 18-55 kit lens. It's certainly not very wide on a crop camera. You have the kit lens, do you not? Try setting that lens at 28mm and have a look through it.
    What are you looking for, that the kit lens isn't doing for you? The kit lens is slow (small maximum aperture) but the lens in question isn't much better (not for a prime lens anyway)...and anyway, you don't usually shoot landscapes at wide apertures.
    If you want a wide angle lens for landscapes, I'll 2nd the recommendation for the Canon 10-22mm, it's a great lens. You can comparable lenses from Tamron, Tokina and Sigma. If those are too wide, the Canon 17-40 F4 L is a fantastic lens in terms of image quality.
