Infrared Photography
Discussion in 'Photography Beginners' Forum' started by Yahoozy, Mar 25, 2008.
  1. Yahoozy
    Yahoozy TPF Noob!
    Jan 28, 2008
    640
    San Marcos, CA
    ok so i currently have an Infrared filter in the mail that will arrive in a couple days
    but i want to make sure i actually know what im doing when i get it
    so what are the basics of infrared photography?
    i know that you need an infrared filter, a camera that recognizes infrared light, and a tripod because it takes a long exposure due to the darkness of the filter
    is there anything im missing for basic infrared photography?
    thanks =P
  2. Yahoozy
    Yahoozy TPF Noob!
    Jan 28, 2008
    640
    San Marcos, CA
    sorry, also its digital, in case anyone was wondering
  3. Tasmaster
    Tasmaster TPF Noob!
    Jan 26, 2008
    301
    A few random things off the top of my head:
    Processing is usually a big part of the final image, either monochrome or color.
    Related to the above: especially if you want to do color IR, shoot RAW, or at least find a custom white balance that will give you good results. This will take some practice and getting used to.
    You need to know just how much IR light your camera allows to reach the sensor but you'll find that out soon enough. The trend is the more modern the camera, the more IR it manages to block (because it can affect the quality of visible spectrum photos).
    IR wavelength focuses at a different point than visible light, so you will need to adjust focus for optimal sharpness (it won't be a disaster if you don't though, just soft). Some lenses have a dot at the focus ring that indicates the necessary adjustment for IR.
  4. Yahoozy
    Yahoozy TPF Noob!
    Jan 28, 2008
    640
    San Marcos, CA
    sweet, thanks
    ill try those and see how it goes =P
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Basics:
    Set your white balance as cold as it will go (use custom if possible).
    Autofocus will work through the filter but aim the camera before you put the filter on because your eyes won't.
    Use a tripod.
    Your light meter will not work through the filter. Use manual and don't be surprised if you need >5 second exposures at wide apertures on a sunny day.
    Some lenses will display a spot in the middle. This often goes away at higher apertures.
    Editing is the key read Astrostu's post #7 here: http://www.thephotoforum.com/forum/showthread.php?t=105589
    Don't be afraid to try different things:
    http://www.thephotoforum.com/forum/showthread.php?t=116740
  6. Yahoozy
    Yahoozy TPF Noob!
    Jan 28, 2008
    640
    San Marcos, CA
    there we are thats great!
    that helps a lot hahah
    thanks =D
  7. jdjd1118
    jdjd1118 TPF Noob!
    Dec 19, 2007
    191
    New Hampshire
  8. Yahoozy
    Yahoozy TPF Noob!
    Jan 28, 2008
    640
    San Marcos, CA
    hahah already checked that thread out
    and thanks for the site =P
  9. GerryDavid
    GerryDavid No longer a newbie, moving up!
    Sep 18, 2003
    1,221
    9
    Virginia
    Theres a filter infront of the sensor that blocks infrared light, if you remove this *or hire someone to* then the shutter speeds go back to normal, and you can use the light meter I believe. Still need to use the IR filter that blocks normal light. But then you probalby cant use the camera for normal pictures. :0)
  10. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    You'll get a "hotspot" with some lenses. It's just a bright circle in the center of the frame. The more stopped down the lens is, the bigger the spot is.
    You won't see it on all lenses, from what I've read it's due to some lenses being 'optimized' for visible and IR light, while others are only optimized for visible light.
    Also, I've read (and my own experience seems to confirm) that aperture will not affect DOF the way you're used to. You'll have just as much DOF wide open as you will stopped down. Not sure why... But it seems to be the case, to some extent at least. ...So, shoot wide open - the hotspot (if you get one) will be smaller, and you'll have shorter exposure times.
    It's been a while since I've played around with my IR filters (working nights, don't get to play in the daytime much anymore...), so if any of the above is incorrect (I don't think it is, but hey - I wouldn't call myself an expert) I'm sorry...
  11. GerryDavid
    Sep 18, 2003
    1,221
    9
    Virginia
    Hmm, wheres a good spot to get one of these filters, and for cheap, since this will just be for fun, no need for a $$$ filter. :0)
    I did a search on b&h but the ones I seen there was pretty expensive.
  12. GerryDavid
    Sep 18, 2003
    1,221
    9
    Virginia
