Is shutter count always accurate?
Discussion in 'Digital Discussion & Q&A' started by Sleepy_Sentry, Jul 3, 2009.
  1. Sleepy_Sentry
    Sleepy_Sentry TPF Noob!
    May 14, 2007
    215
    Berlin
    I have a used Canon Rebel XSi I bought from Adoroma last month for $499. The camera is in near mint condition with only a barely noticeable surface scratch near the strap hook that you have to turn the camera to see.
    I decided to check the shutter count today and was surprised by the number: 8945.
    So far I have only shot about 400 pictures, but given the condition of the camera, I find it odd that the previous owner took 8,000 shots with it. Wouldn't a camera with so much use show the wear? Is it possible that my shutter count is wrong?
  2. rom4n301
    rom4n301 TPF Noob!
    Dec 28, 2007
    614
    quick question.. i got a rebel xt.. how do u check the shutter count
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Show wear? What does shutter count have to do with outwardly wear? If you set the camera to do 3fps I think you would be able to get to 8000 shots within a couple of days.
    I have a friend who's camera has done upwards of 60000 and has no signs of wear. On the other hand I dropped mine for the first time at around 3000.
    Outside signs of wear show only how well the camera was looked after.
    Shutter actuations show how much it was used. The two have little to do with each other.
    rom4n301 often the actuations are available somewhere in the EXIF data. If not just google XT shutter actuations.
  4. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    I have one too.
    As far as I know, there is no way to check the actuations. File number is the only indication.
  5. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    14,017
    2,657
    Wichita, Kansas, USA
    Well there is one way and that is send it to Canon Service. If you need to know that bad and want to pay the price.:lol:
  6. Sleepy_Sentry
    May 14, 2007
    215
    Berlin
    There's no direct relation, of course, but it would make sense that a camera that's been used heavily would have picked up a few bumps and scrapes along the way. Just like a car with 100,000 miles will almost certainly show signs of interior wear.
    Is 8,000 shutter clicks high for a used camera? How many shutter clicks does a camera last?
  7. Josh66
    Oct 31, 2007
    14,604
    1,236
    Cedar Hill, Texas
    I believe most modern dSLRs are made to last upwards of 100k, though the lower end bodies (like the rebel series) may not make it that far.
    I have around 7000 on mine. Still running strong.
  8. KmH
    Apr 9, 2009
    39,505
    5,330
    Iowa
    An XT shutter should be good for an aveage 30,000 actuations. Like Josh said for Canon you look at the file number.......if it hasn't rolled over.
    Your XT isn't listed here but you can poke around and try to extrapolate from the other canon camras:
    Shutter Life
    For newer Nikon's just make an image in camera as a JPEG, upload it to your computer and look at the 'Maker Notes' with an EXIF reader like Opanda.
    [​IMG]
  9. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Yeah but the Nikons supposedly reset when you do a Firmware upgrade or so I have heard. I should do a check on mine since I recently upgraded mine.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    No they don't. And every camera is different. Not just Nikons or Canons. While the Nikon D90 for instance shows you the shutter count in EXIF according to the above, the D200's shutter count is encrypted and embedded in the RAW file so it's a bit of effort to extract.
    I just did a quick google and found that there is no way to get the shutter count out of a Nikon 350D. The 1D's embed it in the ExIF, and I didn't search any further than that.
  11. KmH
    Apr 9, 2009
    39,505
    5,330
    Iowa
    Of, course newer in digital means a couple of years and the D200 is rapidly approaching 4 years old.
    So, I went ahead and snapped a quick JPEG with my D200 and Opanda reads the shutter count no sweat. (It's in red down near the bottom.)
    [Image]
    Make = NIKON CORPORATION
    Model = NIKON D200
    Orientation = top/left
    X Resolution = 300
    Y Resolution = 300
    Resolution Unit = inch
    Software = Ver.2.00
    Date Time = 2009-07-04 21:46:13
    White Point = [313/1000, 329/1000]
    Primary Chromaticities = [64/100, 33/100, 21/100, 71/100, 15/100, 6/100]
    YCbCr Coefficients = 299/1000, 587/1000, 114/1000
    YCbCr Positioning = co-sited
    Exif IFD Pointer = Offset: 352
    GPS Info IFD Pointer = Offset: 26720
    [Camera]
    Exposure Time = 1/3"
    F Number = F4
    Exposure Program = Manual
    ISO Speed Ratings = 100
    Exif Version = Version 2.21
    Date Time Original = 2009-07-04 21:46:13
    Date Time Digitized = 2009-07-04 21:46:13
    Components Configuration = YCbcr
    Compressed Bits Per Pixel = 4
    Exposure Bias Value = -0.33EV
    Max Aperture Value = F4
    Metering Mode = CenterWeightedAverage
    Light Source = Cool white fluorescent (W 3900 – 4500K)
    Flash = Off
    Focal Length = 55mm
    Maker Note = 25680 Byte
    User Comment = (C)2009KHARRODPHOTOGRAPHY
    Subsec Time = 0.73"
    Subsec Time Original = 0.73"
    Subsec Time Digitized = 0.73"
    Flashpix Version = Version 1.0
    Color Space = Uncalibrated
    Exif Image Width = 3872
    Exif Image Height = 2592
    Interoperability IFD Pointer = Offset: 26688
    Sensing Method = One-chip color area sensor
    File Source = DSC
    Scene Type = A directly photographed image
    CFA Pattern = [G,R],
    [B,G]
    Custom Rendered = Normal process
    Exposure Mode = Manual exposure
    White Balance = Manual white balance
    Digital Zoom Ratio = 1x
    Focal Length In 35mm Film = 82mm
    Scene Capture Type = Normal
    Gain Control = None
    Contrast = Normal
    Saturation = Normal
    Sharpness = Normal
    Subject Distance Range = unknown
    Gamma = 2.2
    [Interoperability]
    Interoperability Index = R03
    Interoperability Version = Version 1.0
    [Thumbnail Info]
    Compression = JPEG Compressed (Thumbnail)
    X Resolution = 300
    Y Resolution = 300
    JPEG Interchange Format = Offset: 26848
    JPEG Interchange Format Length = Length: 9164
    [Thumbnail]
    Thumbnail = 160 x 120
    [MakerNote (Nikon)]
    Makernote Version = 0210
    ISO Speed Used = 100
    Colour Mode = COLOR
    Quality = FINE
    White Balance = FLUORESCENT
    Sharpening = AUTO
    Focus Mode = AF-C
    Flash Setting = REAR
    Auto Flash Mode =
    White Balance Bias Value = 0
    White Balance Red, Blue Coefficients = 426/256, 550/256, 256/256, 256/256
    000D = 00, 01, 06, 00
    Exposure Diff = FC, 01, 0C, 00
    ThumbOffset = 2366
    Flash Compensation = 00, 01, 06, 00
    ISO Speed Requested = 100
    Photo corner coordinates = 0, 0, 3872, 2592
    0017 = 00, 01, 06, 00
    Flash Bracket Compensation Applied = 00, 01, 06, 00
    AE Bracket Compensation Applied = 0EV
    001B = 0, 3904, 2616, 3904, 2616, 0, 0
    001C = 00, 01, 06
    001D =
    001E = 2
    0020 = 1
    Tone Compensation (Contrast) = AUTO
    Lens Type = Nikon G series Lens
    Lens Min/Max Focal Length, Max Aperture = 550/10, 2000/10, 40/10, 56/10
    Flash Used = Flash Not Used
    Auto Focus Area = 03, 00, 00, 01
    Bracketing & Shooting Mode = 0
    008A = 2
    008B = 3B, 01, 0C, 00
    Colour Mode = MODE1
    Lighting Type = NATURAL
    0091 = 30, 32, 30, 37, 49, B3, CC, FA, 59, C9, 57, 9D, CA, 8A, B1, D0, 0C, 65, DB, 6E, 1E, EB, D5, DC, 00, 41, 9F, 1A, B2, 67, 39, 28, 34, 5D, A3, 06, 86, 23, DD, B4, A8, B9, E7, 32, 9A, 1F, C1, 80, 5C, 55, 6B, 9E, EE, 5B, E5, 8C, 50, 31, 2F, 4A, 82, D7, 49, D8, 84, 4D, 33, 36, 56, 93, ED, 64, F8, A9, 77, 62, A0, 87, C9, 0C, 50, 45, BA, CE, BF, 7B, BB, DE, B4, 21, 83, 72, 4A, 47, 59, 89, B7, 3D, C3, 66, 7D, 42, FD, 15, 40, 99, 07, 6C, 3A, FF, E1, E0, FC, 50, D8, FD, 9D, 3B, 05, E6, AB, 74, CF, 6F, 32, 9E, 69, 03, DB, D7, AC, 69, 39, D7, C4, C4, 98, 2F, D9, 3D, F5, BF, 0E, 6F, 83, 25, 1B, 2E, 5E, 9E, 20, AD, 71, 01, 19, DA, 34, 27, 79, 68, B0, E2, 1C, 0A, 39, 1C, D1, 8B, 17, A9, D8, 0D, 6F, FE, 33, 61, AE, 08, 99, 9E, 01, BE, 28, E8, 1A, 55, 7E, A9, 4C, 83, 89, 95, 45, CD, 63, 76, 69, AC, B6, 9E, 3A, 69, B2, 22, AA, 4E, 55, CC, 8E, 05, 3B, 8E, FE, 9F, 4D, E1, D1, E2, FF, 2B, F7, 54, 09, 73, 47, 7D, 33, 1A, F4, F3, 33, 85, AF, 04, 47, 52, 7A, BE, 22, A1, 3C, F4, C9, 3F, CE, F4, C5, AC, 30, D1, 8F, 5A, C2, 77, BA, C1, F4, ED, 9A, 5F, 3F, 13, 4D, 8C, D8, 49, D7, 82, 4A, 2F, 33, 50, 8C, E5, 5B, EE, 9E, 7B, 55, 5C, 80, C1, 1F, D0, 33, 4D, B9, A8, B4, DD, 23, 86, 06, A3, 5D, 34, 28, 39, 67, B9, 1A, 9F, 41, 0F, DC, D5, EB, 1E, 6E, DB, 65, 0C, C0, B1, AF, 22, 02, 57, C9, 58, 04, CB, B3, B6, D6, 13, 6D, E4, 78, 29, E7, E2, EA, 10, 51, B0, 2C, C5, 7B, 4E, 2E, 4B, 75, BC, 20, A1, 3F, FA, D0, C7, C9, 08, 54, BD, 43, E6, A6, 83, 7D, 94, C8, 19, 87, 12, BA, 7F, 61, A8, 7C, B5, 0B, 7E, 0E, BB, 85, 6C, 70, F2, CE, 55, 22, B6, 97, 39, A4, 32, D3, 33, 76, 5C, 8D, EF, 18, 78, 17, 35, 8A, C1, 71, 4A, CC, A6, 9B, AE, DE, 2B, 95, 1C, C0, 81, 5F, 5B, 72, A4, F9, 68, F4, 9D, 67, 43, 8E, 36, C8, A1, 40, D1, A7, 72, 5A, AB, FE, 37, 80, C2, D5, 83, 7D, 69, 52, 22, 73, 12, BA, DE, 42, 17, 09, 18, F2, 3B, C7, 42, 39, FC, 99, 9F, A8, F9, 22, BE, 38, DD, 9B, 7D, 6C, 85, BB, 0E, 7D, 13, B0, 3B, 60, 7B, 7F, A0, 11, 84, 18, C9, 14, FD, 01, 27, E6, 43, BD, 54, 08, D9, C7, D2, FA, 3F, A1, 20, BC, 75, 4B, 3E, 5F, 99, 4F, 28, A1, B3, 85, EE, F3, 27, 2B, C2, F5, BD, 11, 61, 32, E6, 9B, 51, 49, 2B, DD, 27, CA, AF, B3, 30, 0F, AC, D9, A6, 1C, C8, D4, 14, 02, 78, 9E, B6, B2, 67, 3A, 7B, 30, 2B, A7, 80, 85, 42, DC, 19, A9, 97, E5, 44, 98, 8A, C0, B1, 58, A5, 6F, 46, EA, 0C, E6, 1E, 53, 59, 2D, C6, 80, 00, 4A, C3, 86, 50, 30, 2B, 52, FD, E9, 54, FB, 67, 75, EC, 68, 8A, D3, DE, AF, 77, FA, 22, BE, CB, F4, D7, A2, 75, BC, DE, 51, 9F, 5A, BE, D7, 17, C1, 31, 26, 03, 03, 02, 48, 99, FF, 20, C0, C4, 51, 36, 4C, F1, 53, 4E, 8E, 3B, 51, B7, F0, 11, 1B, F7, 22, B7, 3C, 2F, 24, 2D, 06, 81, F6, 73, 58, B4, 98, 88, 1D, C2, 0A, 6F, FA, 50, 4C, 25, 1F, C0, 5E, AB, 15, 9C, 40, 01, DF, DA, F2, 27, 79, E8, 74, 1D, E3, C6, C6, C5, 24, CA, E8, 41, D8, 8B, DA, DF, 01, 40, 9C, 15, AB, 5E, 2E, 1B, 25, 4C, 90, F1, 6F, 0A, C2, 97, 89, 93, C5, 18, 65, E9, 88, 57, 19, 3E, 3D, 76, 86, 22, AA, 4F, 11, F0, EC, 05, 69, 2E, FE, 8B, 67, 5C, E0, E1, AD, 9F, 92, 07, CB, ED, 14, FD, 51, 83, 66, C3, 6F, 73, 88, 59, 15, 9B, 7A, BF, 73, 6A, 3C, F5, 9F, E2, CE, FB, 11, F1, 30, D1, DB, BF, 62, 77, A9, F8, 64, ED, 93, 56, 36, 33, 4D, 84, D8, 49, D7, 82, 4A, 2F, 31, 50
    Hue Adjustmen = 0
    Noise Reduction = OFF
    0097 = 30, 32, 30, 37, 01, 00, 00, 00, 00, 00, 8C, BA, 02, F0, F4, BD, 76, DF, EF, 30, 9D, 2A, 67, FF, FB, 30, 79, 6D, 7B, AB, 0F, 72, D2, BA, 68, 97, 49, C7, B9, 15, 6B, 5C, 52, 08, 1C, 11, 05, A2, A7, 1B, 48, D3, 3E, 52, 30, 7E, 2C, 8C, FE, F6, C3, C9, 90, FD, 5E, 51, 42, 7B, 60, 3F, 22, EA, 30, 2A, D9, A4, 8C, 55, E6, B8, AB, 2C, 98, 95, 66, 78, DC, 55, 65, 00, 41, 6B, 41, 0A, 0C, 57, 76, 41, D4, 91, 8F, 48, 4A, B4, 80, 79, 52, 08, 22, 0D, DA, 06, E7, 7E, F3, B3, 9C, F5, DB, AA, 29, 77, FF, 70, 46, 54, E2, 6D, 7B, D5, E7, 95, 0B, 3A, 62, E0, F0, 86, 68, 5A, 00, 38, FF, 79, B1, C9, 21, 1E, B3, 5D, BD, 3D, F7, B4, 2A, F5, 5A, BA, 68, C0, 80, 46, D7, B0, E4, 68, 03, 6A, 9C, 65, 29, 04, 12, 60, FB, 66, E5, 2B, 6E, 82, 06, BA, 07, A7, 7D, 7E, 98, F5, 84, F6, 98, 22, 6B, D3, 0A, 2B, 4C, 37, 95, 85, 2E, EA, C1, 13, B2, ED, 28, 1C, 26, C3, 69, C0, 49, DB, 7A, 81, C6, BB, A4, DF, C4, 26, 95, CE, FE, 2A, EA, 19, A5, 9F, 6E, FE, 84, 02, 04, 4D, DE, 27, 6C, DE, 55, 4B, 95, 52, CA, B6, D0, 4F, 0F, 68, 1C, F7, 09, 53, D1, D8, 5A, 03, F4, D6, 0E, 9A, C9, 39, 26, E5, 41, CC, 89, C2, E2, 07, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, B6, B3, CD, 04, 58, C9, 56, A8, CB, AF, B0, D0, 0E, 43, C8, 7D, 1E, EB, D5, DC, 00, 41, 9F, 1A, B2, 67, 39, 28, 36, 6E, A7, 5D, 86, 0B, D9, AD, AA, 9C, E3, 3E, 9A, 1D, C1, A8, 5D, 83, 6B, D2, EE, CC, E5, 91, 52, 01, 2D, 30, 82, 7D, 49, 4F, 86, 21, 31, 1D, 17, D1, AE, 26, BA, E9, 34, 22, 68, 0C, D1, 30, AC, 45, FB, 63, BE, CB, F5, 3C, A0, 21, BF, 7A, 52, 47, 59, 88, D4, 3D, C3, 66, 26, 03, FD, 14, 48, 99, 07, 92, 3A, FF, E1, E0, FC, 35, 8B, FE, 8E, 3B, 05, EC, F0, 11, 4F, AA, 22, B7, 68, 38, 25, 2D, 52, 96, F7, 73, 0C, C4, 99, 89, 96, C2, 0B, 6F, F0, 90, 4D, 25, 1A, 2E, 5F, AB, 14, 9C, 41, 01, DE, DA, F3, 27, 79, E8, 74, 1D, E3, C6, C6, E3, 1D, 74, E8, 79, 27, F2, DA, DF, 01, 40, 9C, 15, AB, 5E, 2E, 1B, 25, 4C, 90, F1, 6F, 0A, C2, 97, 89, 98, C4, 0D, 73, F6, 96, 53, 2D, 24, 38, 69, B7, 22, AA, 4F, 11, F0, EC, 05, 3B, 8E, FE, 8B, 35, FC, E0, E1, FF, 3A, 92, 07, 98, 48, 15, FD, 02, 26, 67, C3, 3C, D4, 89, 59, 46, 52, 7B, BF, 20, A0, 3D, F5, CA, BE, CF, FB, 44, AC, 31, D1, 8E, 6A, 63, 77, A8, 52, 65, ED, 92, 56, 34, 15, 4D, 75, DB, 49, D7, 82, 4D, 2B, 34, 53, EF, E4, 74, FE, 8C, 6B, 4F, BD, 80, C1, 1F, BE, 32, E7, B9, A9, B4, DD, 22, 85, 06, 49, 5F, 36, 2A, 3B, 01, B4, 17, 92, 14, 00, D1, D8, F7, 11, 6A, D6, 61, 08, D0, B7, A6, 99, 02, 54, C9, 58, 04, CD, B3, B6, 22, E3, 9D, 38
    0098 = 30, 32, 30, 31, AB, 82, CE, 04, 49, AC, 04, 92, F1, FC, 31, E0, 30, F7, EB, 60, 4F, CC, 88, DC, 00, 41, 9E, 19, B3, 67, 38
    009A = 605/100, 605/100
    00A2 = 3734828
    00A3 = 0
    00A5 = 355
    00A6 = 91
    Total Number of Shutter Releases for Camera = 446
    00A8 = 30, 31, 30, 31, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
    Image optimisation = NORMAL
    Saturation = AUTO
    00B0 = 30, 31, 30, 30, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00
    00B1 = 0
  12. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    :lol: That shows how often I visit this topic. This function appears to have been added with a firmware upgrade... 3 years ago. :lmao:
    I was still using a program called "Preview Extractor" which extracts the camera JPEGs and the shutter count out of a RAW file.
1f9ab1ac423887f3860582a9
52f4cfa82ea7ed2e91df7aacc7440a36
550d shutter count
d7 shutter count
find shutter count on 550d
is 8000 shutter acuations a lot for a digital camera
is 8000 shutter count many
is 8000 shutters a lot
shutter count 2d
shutter count d7?
