ISO 1600 B&W pics came out crappy!
Discussion in 'Beyond the Basics' started by Axel, Nov 3, 2004.
  1. Axel
    Axel TPF Noob!
    Jul 19, 2004
    254
    US East Coast
    I just wonder if it's normal that the pictures taken with an ISO 1600 B&W come out with extreme contrasts... The black is very black and the white is very white...
    Also, I thought they were good for dark pictures, but the ones I have taken in the dark came out like crap! All black! Is it that hard to take good pictures with an ISO 1600? I took a roll of ISO 100 the other day and they came out extremely nice. And for some reason I was able to use faster shutter speed too, than with the 1600, which surprised me a lot...
    Any thoughts on these comments?
  2. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Contrast is affected by the film type, but also exposure, development, printing, and paper choice.
    Low light photography is tricky. I would expect that you will have to practice to get it right on a regular basis.
    ISO 1600 is 4 stops faster than ISO 100. In the same lighting conditions you should be able to significantly faster shutter speeds (like from 1/125th at ISO 100 to 1/2000th at ISO 1600), or open the lens up 4 f/stops, or a combination of the two.
    Keep trying.
  3. Axel
    Axel TPF Noob!
    Jul 19, 2004
    254
    US East Coast
    Thank you very much!
    I would appreciate if somebody could tell me something about the pictures here:
    [​IMG]
    [​IMG]
    These are both taken at the same spot. Why does the B&W come out so extremely dark in comparison with the color one? THe color picture is an ISO 400 I think.
    [​IMG]
    Here the blacks are very black and the whites very white... I don't like that and don't know if that is typical for ISO 1600 or if it is my fault. AFAIK I adjusted speed and exposure according to the camera's meter and it still comes out this way! The foreground (the car) is acceptable, but the farther away, the more irritating contrast become.
    [​IMG]
    Another example of the same problem as the previous picture...
    [​IMG]
    And the last one which is worth showing.
    The rest are basically either pitch black (I can't even recognize what they are!!!) or simply to embarrassing to show...
    Well I changed my mind...
    This one too...
    [​IMG]
    However, the contrasts are so very hard. I llike them smoother... Is that due to the film speed? It should be said that Fuji themselves developed the film, but they were printed at the local photo shop.
    Sorry. I had to edit the post since the Geocities site was crappy. This should be better at least...
  4. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    Try putting a green filter when you shoot that corridor.
    I don't they're THAT bad. I like quite a lot of them
  5. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    usa. soon to be a euro boy.
    The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information.
    crud.
  6. Axel
    Axel TPF Noob!
    Jul 19, 2004
    254
    US East Coast
    Should work fine now though...
  7. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    well, without being able to see them, i understand your concern and Matt has the words of wisdom for you.
    "Contrast is affected by the film type, but also exposure, development, printing, and paper choice."
    development choices and printing methodology are critical, especially in high speed situations. since you don't have control over these keep shooting, but try different metering techniques.
  8. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    I'm new to photography and have never used 1600 or B&W film so this is just me throwing out ideas for the people who know what they're talking about to elaborate on if correct, or dismiss if wrong. It looks like the metering is the problem. It looks to me like the shutter has been open too long, to give you the white areas, but not long enough, to give you the black areas. You can really see that on the corridor photo where the lights are over exposed. It looks like you were shooting things which had very bright and very dark areas at the same time. As a result, the camera has metered to give you the middle ground. This would mean that the dark areas are a little under-exposed and the very light areas slightly over-exposed. But everything in-between should be fine.
    When you took the photos outside, was it a bright day? If so, the same thing would be happening.
    Just what came to mind when I saw them. I could very easily be talking out of my arse. :mrgreen: And I think they're good. Even if it isn't what you wanted. :)
    What would a green filter do DocFrankenstein? As I said, I've never shot B&W. :)
  9. Axel
    Axel TPF Noob!
    Jul 19, 2004
    254
    US East Coast
    It was a rather cloudy and grey day... Apart from that, even if it was a bright day, I should be able to tkae picture with a fast shutter speed, which in turn should make them very clear... Just my thoughts...
  10. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    ahhhh, i can see them now.
    welcome to shooting at 1600 with lab processing and printing - these are not at all off for that process.
    it does appear, however; that some were shot in bright daylight, more than likely late morning to early afternoon as shadows are small, if even evident. 1600 is high contrast film to start. add to it a bright afternoon and, yeah, you'll get contrast from...you know where.
    i actually quite like the b&w shot of the hall; i like the textures and patterns. looking at the walls there are most certainly some middle zones captured. your blacks/almost blacks and whites/almost whites have been pushed to all black or all white which is typical for high speed film. if you don't have access to be able to process and print for yourself, the hall shot is near what you can expect from the film in given conditions.
  11. motcon
    motcon TPF Noob!
    Jul 18, 2003
    1,410
    i do see some shadows cast and some reflections, so the sun must've been out for some of the shots.
    the characteristics of high speed film are grain and contrast, which can be controlled if you develop it yourself.
  12. Axel
    Axel TPF Noob!
    Jul 19, 2004
    254
    US East Coast
    IOW, it doesn't get better that it is? That's disappointing... Especially since I have another 1600 to develop plus one more film in the freezer AND an additional Kodak 3200!!! If this is going to be the result, I seriously have to think about it before shooting more of those... And I don't have the equipment to develop and print myself. Don't have the ability to get a darkroom either... So, I'm pretty sold here!
